Changed out the TV on my 06 Hurricane and wasn't very difficult. The winch makes removal pretty easy. As Jim stated pop the four button covers off so you can get to the screws holding the padded bottom cover off. There are additional screws that will be uncovered to get the entire bottom frame off. With the framing off you can get to the hardware that holds the TV in place so remove those. Unplug power and disconnect the cable RF input and start cranking the winch thru the hole in the passenger side overhead compartment. Once down you can remove the TV from the winch and start working on a mount for the replacement.
Also save the winch. If you ever intend to carry a unmounted spare tire behind the gas tank between the frame the winch should work to hold the tire in place.
Pics of what I did.Before
After
2006 Hurricane 31D built on a 2006 Ford F53
