Overhead Front TV
gilbarca
Just wondering how to remove the overhead front TV in a 2007 Hurricane 31H class A motorhome. Want to switch it out for a led model. I think it is on a crank up cable system but am not sure. Hoping someone out there has done the change out and can steer me in the right direction. Thanks
5 REPLIES 5
gilbarca
Thanks for all the help....Dale the posting was awesome, definitely going to make my changeover a lot easier. Thanks again to all hopefully I can return the favour.
Safe travels to all !!
Dale_Traveling
Changed out the TV on my 06 Hurricane and wasn't very difficult. The winch makes removal pretty easy. As Jim stated pop the four button covers off so you can get to the screws holding the padded bottom cover off. There are additional screws that will be uncovered to get the entire bottom frame off. With the framing off you can get to the hardware that holds the TV in place so remove those. Unplug power and disconnect the cable RF input and start cranking the winch thru the hole in the passenger side overhead compartment. Once down you can remove the TV from the winch and start working on a mount for the replacement.
Also save the winch. If you ever intend to carry a unmounted spare tire behind the gas tank between the frame the winch should work to hold the tire in place.
Pics of what I did.
Before
After
2006 Hurricane 31D built on a 2006 Ford F53
OldF__t
First remove the bottom from the tv cabinet. There are four screws under plastic snap caps holding it on. There are several screws holding the tv to the metal chassis in the cabinet that need to be removed. After the tv is loose in the chassis you can winch in down using a socket and extension through the access hole in the top left of the passenger side overhead compartment.
Jim
2021 Grand Design 303RLS
2019 Ford F350 DRW LB CC
mike_brez
BFH
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
Tom_Barb
You can see the hex knob from the right hand over head compartment.
