โMay-12-2013 04:19 PM
โMay-14-2013 05:24 PM
โMay-14-2013 07:53 AM
โMay-13-2013 08:47 PM
shaneperch wrote:
I would like to know. can you get high geared rear ends for the P30 chassis? someday I would like to get a higher geared ring and pinion to get the rpms down a little. anyone ever done that?
โMay-13-2013 12:05 PM
โMay-13-2013 10:52 AM
โMay-13-2013 10:44 AM
shaneperch wrote:And that is the exact question I have, based on my experience with TC slip.sjholt wrote:
You might look around for a used Gear Vendor overdrive unit. It worked nicely in the P30 I had..New ones run $2700.
They bolt up to the turbo 400 trans, then all you have to do is shorten the drive shaft- about $120.
How much mileage gain did you see using that overdrive?
โMay-13-2013 10:43 AM
โMay-13-2013 10:34 AM
โMay-13-2013 10:33 AM
โMay-13-2013 09:21 AM
โMay-13-2013 07:30 AM
โMay-12-2013 09:42 PM
โMay-12-2013 09:11 PM
