Power Gear leveling Jack's
fairway2002
Hello
The dealer cut my leveling jack line. Do you know what line on the jack is up and down?
all 8 lines are tied together so I can not follow back each jack has a upper and lower hydrolic line running to them
Thanks
3 REPLIES 3
fairway2002
Thanks. I'm fixing because I can handle this. They might screw something els up.
Triker33
Why are you trying to fix. That problem should be the dealers to fix.
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
harold1946
The top one is for extending. The lower is for retracting
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer Sport toad
