loggenrock
Nov 04, 2018Explorer
re: fridge. Look at the bottom seam accessed from the lower outside panel. I found ours needed to be recaulked.
Compartments. the comment about holes that cables run thru is valid. Discovered they had sealed a cable accessing 1 outside compartment thru a large hole. That was good. Issue was the cable was run thru a split plastic wire loom to protect the cables from chafing. Acted like a tube - water could enter from the outside into the split loom, only to run out inside the compartment. Simply a poor design.
Compartments take 2... Check the seams where the compartment meets the bottom of the camper floor, and meets the sidewall of the rig. They use a piece of weatherstripping type material. I used roofing tar to make sure they were water tight joints.
Bottom line - climb underneath with a good light and start looking!
38,782 PostsLatest Activity: Sep 19, 2026
