problem with right front turn signal
TIMETOTRAVEL
I have a 2003 Tiffin Allegro Bus, when you turn on the head lights the right signal light... lights up on the dash , even without pulling up the blinker arm, but not on the outside. If you do pull up the signal to activate the right turn signal the bulb just stays lite but doesnt blink, however is lite on the outside, just not blinking.
When the lights are off the signal works as it is suppose to.
Is the a double element bulb which could cause this...just asking. Have not had a chance to carry it to a repair location...anyone with a suggestion I would appreciate it.
9 REPLIES 9
teetah
Having a similar problem, only with the left light. Thought I'd found the problem with some bad wiring, but just had it do it again. My problem is it doesn't happen every time I drive the rig.
2002 Rexhall Vision
2014 Ford Focus = toad
Just runnin' footloose and fancy free
ddndoug
Were you able to rectify the problem?
Doug
2009 Four Winds Hurricane 33T
F53 Ford Chassis w/Triton V-10
bhivetravels
enblethen wrote:
Lamp outage indicator. Some where on that side is a lamp out. Could be side marker, turn signal or taillight.
Ditto that was my same problem exactly!
Jim and Monica
Maj. USAF Ret. โ€” High School Teacher Ret.
2016 Jayco Pinnacle Ford 350 Turbo Diesel
Full-Timing with Meiko and Marlie:C
enblethen
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
ddndoug
Check your right rear light.
Doug
allbrandauto
if not the bulb you have a ground problem to check it use a 12 volt test light ground one end of it use the probe on brass part of bulb turn on parking lights if test light lights up you have a ground problem check ground wire the same way if it doesn't light up you have a bad socket
TIMETOTRAVEL
Thanks ...Ranger... will pick one up and replace it today.
rongtamw
If the directional light bulb is in the same housing as the headlight bulb you could have a ground problem.
Ranger_Smith
Put a new bulb in. Sometimes when they go bad the filament shorts to the other filament which seems like what is happening with your situation
Where we are now
Amateur Radio Operator WW1SS . . . Flex 6500 PGXL and TGXL
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
