sycamore92's avatar
sycamore92
Rearend wobble on Newmar
We have a new 2018 Newmar, Ventana. We tow with a blueox tow bar.
We have experienced a bad rearend wobble while making a left turn. It doesn’t happen
All the time. Have driven thr rv for apx. 2,000 miles and the wobble has happened
3 times. Have taken it to Freightliner and they can not find any problems with the tag axle or rearend of the rv. Any suggestions? Have used the same tow bar on our other rv for years and have never experienced this problem! Any suggestions?
    What type of car do you tow?
    Some new models are having this problem,very well be the car and not the motorhome...C
  • Sounds to me like the tag axle has to much air in the bags and the tires are skipping. Per chance do you have an air dump for the tag so when going around a corner you can relieve the down pressure on the bags?
  • SisecarFlip, the tag axle steers with the front. I’ve had that checked out. But thanks for the
    Suggestion.
  • There is a known problem with wobble that happens when flat towing several makes of cars (including my Malibu). When in a turn and you hit a bump it sets off the tow car causing the front tires to wobble back and forth so badly that you think is coach has a serious problem like a flat tire or the rear axle is coming off! Upon investigation, it happens on vehicles that have electric power steering. One time it happened I remembered to check the rear camera and was surprised to how badly the car shook. Some have used a strap or bung cord on the steering wheel to the door post (like a tow truck operator would do) to minimize the problem.
    Dave
    07 Revolution
  • The 'death wobble' referenced comes with cars that have ELECTRONIC steering. When you disconnect it thru removal of the fuse, or batteery cable, it will cause what you're describing. That said, if it is, in fact, the death wobble you're talking about it will be a really bad wobble. Yes, Ford, Chevy and Jeep all have this issue. The fix is to power your steering while turning off everything else. Chevy fixed theirs by removing a different fuse and Jeep provided a wiring harness to fix theirs. Ford, I believe, still refuses to acknowledge the problem exists...Dennis
    Here is a video.
    Here is Chevy's fix.
  • If you have the 'not feeling well' wobble (not bad enough to be a death wobble) in my case it was caused a couple times by my incorrect setup. I have a 36' Class A, Blue Ox tow bar, and Saturn toad. A couple times now, I have inadvertently hooked up the drivers side pin connection from the Blue Ox upside down. Driving along seemed normal for the most part, but then I'd notice a wobble. The wobble would come and go, but was worse on long left turns.
    Stopping the rig, and flipping the Blue Ox connector over at the car fixed it.
    Any chance you might be doing that?
