Oct-04-2015 12:12 PM
Oct-08-2015 07:52 AM
Oct-08-2015 05:45 AM
Oct-06-2015 10:21 PM
Oct-06-2015 10:16 PM
jwmII wrote:
A vapor barrier laid down before pouring a concrete slab definitely helps but it is not the cure all you would think it is as the concrete above the vapor barrier will absorb moisture and then give it up so it can attack the tires. The best barrier remains metal or plastic right on the tire footprint occupying an area around each tire.
Oct-06-2015 10:10 PM
Oct-06-2015 05:51 PM
Bruce Brown wrote:Kayteg1 wrote:Bruce Brown wrote:
Gravel is fine, a garage is better, a heated garage is the best. :B
I think cooled garage will beat heated garage 🙂
Location, location, location.
Seeing as the OP is "Snow Hawk" and his location is Massachusetts, I'm thinking in this case he'd have all the natural cooling he could stand. :B
Too hot - uncomfortable.
Too cold - things freeze and break.
I'll stick with the heated garage. :W
Oct-06-2015 01:36 PM
Oct-06-2015 11:00 AM
Bruce Brown wrote:jwmII wrote:
Any surface you park on is going to allow moisture up around the tires thus contributing to dry rot of your tires. This includes dirt, gravel, concrete, wood and any other porous surface. Place the tires on metal such as galvanized or aluminum roof flashing. Plastics will work for you as well. Place mats of plastic or cutting boards, etc.
Jacking the vehicle up so the tires clear the floor works too. Get some sheet metal scraps from the local tin shop. Those will work too.
You missed one option; concrete with a vapor barrier. Seeing as the OP is considering concrete, and hasn't poured anything yet, adding a vapor barrier would be cheap, easy, and effective.
Oct-06-2015 04:31 AM
Oct-05-2015 04:46 PM
Oct-05-2015 03:25 PM
Oct-05-2015 03:23 PM
Oct-05-2015 02:36 PM
Oct-05-2015 11:03 AM
