gypsyhounds's avatar
gypsyhounds
Replace gen on Lexur Pleasureway
2006 Lexur Pleasureway . I asked Phil if I could switch the Onan to a quieter one.
He thought the configuration would not match up/fit. But not 100% sure.
Has anyone done this on same model?
    when you say switch-switch to what?. the new onan that came out in Jan 2013 is only slightly quieter if at all
    read this post-linky
  • Thank you Az kid. But that posting doesn't quite answer my question. My rig is a pleasure way not road trek.
  • Onan is onan. your pleasure way used the onan 2800 in 2006.
    it will have to be replaced with the onan 2800 made today.
    if pleasure way can't tell you how can we.
    if Phil does not think it will fit it probably won't.
  • Doesn't really matter, your PW is probably the same set up as the Rt.
    If you read the post you will see the new one is bigger, and wiring on the other side.
    I doubt the new Onan is much quieter than the old one, and Onan is your only choice for a mounted gen-set.
    Have you tried having an Onan resonator added to the exhaust?
    Lots of info in the archives here about the resonator, and other ways to quiet the 2800.
    There are "Search" tutorials in " Forum Tech Support"
  • No, to resonator, but I have looked at it here and other sites with consideration.
    I was in a park once and heard either a Yamaha or a Honda and it was so quiet and purr like I immediately wanted to switch.
    I guess I am out of luck. Oh, Phil was not 100% so that is why I posted here to see if anyone had done it. There are a few good DIY guys here sometimes.
    honda's and Yamaha inverter generators are much quieter-no question-they do not make an undervan model
  • Yep, to emphasize gerry's statement, the quiet inverter generators are for portable use, not for installed use, either under-van or in a compartment. All you could do is put one on an outside cargo rack, where you'd have to go outside to fuel it about every 8-10 hours, shield it from road dirt and weather, and worry about theft.
    And yes, both PW & RT use the same model of Onan, and the recent redesign has created some issues, or worse, with replacing old with new.
    Jim, "The cardiologist's diet? If it tastes good, spit it out!"
  • Thanks. Sadly I will just deal with it and eventually get the part to quiet it.
