Fauquier's avatar
Fauquier
Replacement tires for a Roadtrek RS
Its about time to replace the tires on my 2007 Roadtrek RS . It currently has the original LT 225/75 R16 tires on it. Any recommendations for a replacement tire ?
Thanks, John
  • I agree. Michelins. I have used the LTX M&S on two C classes and current PW 'B'. I find they handle well in the wet and even on icy surfaces although I try to stay away from winter like conditions. They wear well and are reasonably quiet if that is a big factor with 'noisy' motorhomes.
  • There are almost as many opinions on this as there are people who replace RV tires. If you search this website and other related sites, you will see hundreds of opinions on this subject and I think that is because there are many good RV replacement tires. I replaced my RV tires with Michelins and am happy with them. Whatever tires you chose though, be sure they meet the rv manufacturer's tire specifications. Before buying, I would check the date on the tire that shows when they were manufactured (there is a code on the tire that shows the date). You sure don't want to buy "new" tires and then learn that they are really several years old having been sitting around in some warehouse.
  • I replaced the Hankooks on my Pleasure Way with Michelin LTX MS2. Love them.
  • mine too, I,m going back to the org michilins , they worked good, wore good and no problems,for 7yrs why change.
