Replacement Window Slide Lock
fijidad
One of the locks for a sliding window on our 2002 Monaco Windsor has been broken, and I've not been able to find a replacement. Does anyone know of a supplier for these? There are a short and a long version, and I need the long one.
I haven't figured out how to add a picture, so...any help would be appreciated.
8 REPLIES 8
fijidad
William B wrote:
https://pnwtool.com/Prestashop/index.php
This place had the right part and I've ordered a couple. Thanks for the tip.
William_B
Full timing since 2004
2007 Holiday Rambler Navigator 45' DD Series 60
2019 Dodge Ram 1500 Limited
Our Blog
ArchHoagland
rgatijnet1 wrote:
They sell "sex bolts" on Amazon which can be used to replace some rivets and look better than a shoulder bolt and nut.
If I search on Amazon for Sex Bolts my wife is going to want to know what the heck is going on........
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
enblethen
You will need to search here.
Window parts
Atwood bought some window companies.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
rgatijnet1
fijidad
ArchHoagland wrote:
Is that lock held in place with a rivet?
On my Monaco I have a broken one and it is riveted in. I'm not looking forward to drilling it out so I've used a piece of wood down in the channel to hold it closed temporarily.
That's the one. I have the instruction sheet from the last one I bought and it shows drilling that rivet out and replacing it with a threaded "shoulder screw" and nut to hold the new one in place. That is, If there was a new one...
ArchHoagland
US Gear Brakes
rgatijnet1
Contact these people. I'm sure they will have what you need. RV Salvage
