replacing duo therm 3107612 analog thermostat
fizikpal
Good Day,
Looks like I might need to replace my thermostat. I would like to go digital and have all the same functions as my current thermostat (dual fan speed is a must).
Anyone have suggests and more importantly, successes?
The Lynch's
2002 Shasta Cheyenne 308
TOAD: 2003 Honda Civic
Sterling Tow Bar with Brake Buddy
3 REPLIES 3
Old-Biscuit
Duo-therm to Digital with Hi/Lo Fan switch
Very easy, simple upgrade done my MANY...myself included.
donn0128
Here is one
If this is a 4/5 wire configuration, then Hunter Douglas has a decent one for around 25 bucks. Since most home thermostats are 24V and your RV is 12V you will either want a dual voltage or battery powered one. There are several places on the web that have wiring schematics for connecting to an RV. The HD will need the addition of a small SPST switch to get both hi and lo speed AC fan settings. Following the instructions you should be able to do it in an hour or so.
Mandalay_Parr
Best to check with the ac / furnace mfgr for one that is compatible.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
