Sep-13-2017 08:53 PM
Sep-15-2017 07:31 AM
Sep-15-2017 07:23 AM
sgip2000 wrote:rhagfo wrote:mike brez wrote:enblethen wrote:
GFI breaker.
Disconnect the neutral from breaker and connect it to the neutral buss. Disconnect smaller neutral from breaker that goes to neutral buss.
I'm pretty sure doing this will solve the problem. I'm going to grab a different breaker without the gfi so I have it when electrican comes.
Would likely solve the problem, it now is not code compliant as the you have defeated the function of the GFI!
GFCI not required for an RV receptacle.
Sep-15-2017 07:10 AM
mike brez wrote:A 120/240V 50A RV plug is not the same as the older 240V 3 wire dryer plug. The 50A RV circuit is the same as newer 120/240V 4 wire dryer but the dryer circuit may be less than 50A.
With that being said just out of courisity if the dryer and rv have the same readings at the female end I take it that the single 240v for the dryer and the split 120v lines for the rv it is all in the wiring on the inside the dryer or in the rv panel?
Sep-15-2017 06:54 AM
Sep-14-2017 06:01 PM
Sep-14-2017 05:28 PM
Sep-14-2017 11:53 AM
Tom N wrote:
50 AMP RV WIRING
50 AMP HOT TUB/RANGE/WELDER WIRING
NOTE: THEY ARE IDENTICAL
Tom, W3TLN
Sep-14-2017 11:09 AM
CA Traveler wrote:rhagfo wrote:His math and mine is good. 120+120=240. Plus to be more complete add a ground to neutral which will be 0V.time2roll wrote:
That picture seems to have a problem with addition.
'electric doctor photos' needs to take an actual measurement instead of just creating graphics from stray images.
I don't know what math you are using, but the picture is correct.
Plus add a note that the actual voltages can vary.
Sep-14-2017 09:25 AM
GFI breaker.
Sep-14-2017 08:25 AM
Sep-14-2017 08:17 AM
rhagfo wrote:Why do they lose 20 volts L1 to L2 vs each to neutral?time2roll wrote:I don't know what math you are using, but the picture is correct.
Sep-14-2017 08:12 AM
GFI breaker.
Sep-14-2017 07:59 AM
GFI breaker.
Sep-14-2017 07:54 AM
