Safe shore Power
grandpalarry
I bought one of the little yellow power post testers that shows if it's safe to use.
My question is, if I plug into the 120 plug and the lights show OK, does that mean the 30 amp and 50 amp. are safe or just the 120 volt ???
I have a pigtail that I can use to check the wireing threw the 30 amp plug, but what about the 50 amp. ?
I've never had a problem but I pretty much stay at well maintained parks because my wife uses a walker and can't deal with uneven ground.
40 foot DP Holiday Rambler
I donโ€™t need anger management-I just need people to stop pissing me off.
Vancouver, WA
2006 Holiday Rambler DP
16 REPLIES 16
HappyKayakers
Even if the post tests good before you plug in, conditions can change. That's why I use a portable unit from PI all the time.
Joe, Mary and Dakota, the wacko cat
Fulltiming since 2006
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2017 Open Range 3X388RKS, side porch
Rich_D_
Unfortunately that tester will not help you checking the 50 Amp, 240 Volt supply. You can make one that does or purchase one. Here is a link to a home made tester you can assemble for about $35.00.
50 Amp Tester
Rich D. Wanderlodge M450 LXi
