Jun-05-2017 06:17 AM
Jun-06-2017 03:40 PM
DrewE wrote:
Alternately, if you have a winterize suction inlet, you likely can use that to pump water (or a bleach solution) from a container into the fresh water tank by setting the valves for winterizing and filling at the same time. I think pouring the bleach into the hose is the easier method, though; just remember to wear old clothes unless you're far more neat and coordinated than I am.
Jun-05-2017 04:05 PM
Jun-05-2017 10:41 AM
Jun-05-2017 10:16 AM
Jun-05-2017 10:04 AM
Jun-05-2017 09:36 AM
RTrider wrote:
Did a search and could not find my topic even though is likely discussed previously. Likely not using the right search criteria.
Anyway, .....
2009 Tiffan RED. Fresh water inlet fed from the rig water hose inlet through a two way valve. Meaning to fill the fresh water tank you simply change the valve to fresh water tank and it fills through the main system.
The tank has never been sanitized and we think we picked up some water that is not so good.
How do I get bleach into this closed system/tank?
A second related question is I cannot find the fresh water tank drain. I would hate to use the water pump to drain the tank. Where should I look.
Thanks for any help in this matter.
Jun-05-2017 08:32 AM
Jun-05-2017 08:01 AM
Dick_B wrote:
The drain should be directly below the FW Tank but it might require getting under the rig to find it. Mine is a small (1/2 inch or so) plastic pipe with a petcock (1/4 turn valve) on the end.
Jun-05-2017 06:39 AM
Jun-05-2017 06:19 AM
