Sealing roof 97 Bago Vectra
base1957
97 Winnebago Vectra
Can you tell me if the seams here where the over lapped roof meets that rail requires a sealant and if so what do I use.
I can push the roof away from the rail but it is no open unless i depress it.
Also is this the " Roof to sidewall joint"
Would attach pics if i knew how.
thanks in advance.
1 REPLY 1
MaverickBBD
Yes that is the test if it needs reseal. Many posts on the topic. I used Geoseal on mine and led the caulking gun with a screw driver so I could get the caulk down inside.
Tom, Cheryl & Blossom(coonhound mix)
'05 Winnebago Journey 36G w/Cat. C-7 350 hp Freightliner XC
AFE air filter, aero turbine muffler, 4 FSD Konis, ultra track bell crank and Safe-T-Plus
FMCA 397030
WIT 129107
