shower wall
JOERVDREAM
The shower wall is all one piece covering the 3 walls made of a flexible plastic in the 04 Winnebago sightseer I just purchased. All along the top is no longer attached to the wall. I ran my fingers along the inside/back of it and it feels like maybe there's double sided tape that just gave up? If that's the case any ideas on best way to repair that?
8 REPLIES 8
Tom_Cooper
Great thing. I'm fine with the shower, but I ordered a pair just in case
JOERVDREAM
Thanks the washer idea sounds good. What I like about this forum is the replyโ€™s get me to think outside the box. Thanks
Bert_Ackerman
dougrainer wrote:
This is what the RV industry uses in white/off white/beige. These are what I use also. Doug
https://www.amazon.com/Hillman-Group-58552-Nylon-8-Pack/dp/B00NUFQ0QU/ref=zg_bs_6909189011_9/146-126...
That is what we call a Panolam rivet. Can be had off the shelf at the Big Box usually.
MountainAir05
Way better than what I suggested.
dougrainer
Bert_Ackerman
Panolam rivets.....
Lwiddis
Iโ€™m for Mountainโ€™s fender washer idea.
MountainAir05
you can try to seal it back using silicone sealant if you have enough space to put it in. if so put in a small amount and push to wall then pull back , wait a 30 seconds or so and push it back and hold. Do this in as many spots as you can. If not get you some fender washer stainless steel with stainless or brass screws and use them around the top. Ensure you seal each hole with sealant as you go.
