MadDad2's avatar
MadDad2
Slide out length
How much wider than the slide out should an awning be? I have researched all about installing them, and would feel comfortable doing it myself. Looking at the Carefree brand.
  • I would aim for significant awning overlap, 4-6" if possible. This will keep rain off your slide-seals, at least if wind is not blowing the rain against them. The slides are usually double sealed, with an additional inner bulb seal.
  • With one edge of the awning attached to slide, that determines the width, i.e. it can be no wider than the length of the part of the slide to which the awning roller fastens. On mine, that is an overlapping trim about 2 inches from the body of the slide, but for some slide designs it will be the body itself.
About Motorhome Group
38,714 PostsLatest Activity: Apr 10, 2025
