I have a 2002 Damon Intruder 375 Ford V10 chassis. The other day I went to extend my living room slide and it was dead. I had just put it in hours before and all worked well, the engine was off and everything was as it should be. I checked the safety key switch at the panel and the slide switch and both test out with continuity. The next thing I located is the relays and the board up in the outside compartment by the slide motor. Do these relays pull off the circuit board? they seem tight. The next thing I did was check all the fuses in my BCC under the hood. I found two blown 5 amp fuses, replaced them and still nothing. Since I have no manuals or schematics, are the two five amp fuses related to the slide out or is it just a coincidence? I was unaware of something not working that those two fuses are linked to.
Breakdown:
1) Slide Relays removable?
2) Two 5 amp fuses in BCC what are they linked to?
Thank You
Todd
