Solution to Stubborn Water Spots ?
USMC46
I have some stubborn water spots on the coach exterior sides that just will not come off. Does anyone have a proven method of removing these water spots ? Thanks.
Jim & Carmel
2016 Escape 17b
2017 Jeep Cherokee Trailhawk With Factory Tow Package
11 REPLIES 11
teddychamp
Try 50/50 Hydrogen Boraxide and Water. Use it with a spray bottle end let sit for about 10-15 minutes and tab dry with soft cloth. Works like a charm.
Fleetwood Bounder 39R 330hp Cummins Turbo Diesel
Freightliner Chasis
Ford Escape Limited - on ACME Towdolly
Clay_L
I've had good luck with CLR.
For spots that were not as stubborn I used Windex and a nylon mesh scrubby pad and elbow grease.
Clay (WA5NMR), Lee (Wife), Katie & Kelli (cats) Salli (dog).
Fixed domicile after 1 year of snowbirding and eleven years Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
ScottG
BonAmi (NOT Comet) removes water spots and does not scratch. I use it every year to remove the water spots from the glass and mirrors of my truck.
Old-Biscuit
rgatijnet1 wrote:
Go to most any large auto parts store and get a fine or medium CLAY bar. Using this clay bar with soapy water will remove any water spots as well as any bugs or other debris imbedded in your paint. Once everything is removed, you will have a glass smooth surface that is ready for wax. Much safer than any type of rubbing compound.
X2
Clay bar will detail it absolutely clean.......just plan on several days and lots of elbow grease.
Then when done and recuperated.......wax it :B
JoeH
That's what I have had to do in the past... but I use a detailing spray with the clay bar instead of soap. To avoid the spots after you get rid of the current ones, either use a leaf blower to blow off the hard water before it dries, of get a deionizer and do the final rinse with water form it. Here's what I use now
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
DutchmenSport
Try Dishwasher liquid for automatic dishwashers. Use full strength on a soft cloth and follow up with clean water. I use this on my shower stalls, at home and in the camper, and it removed them great. You might let it soak for a little if it's really stubborn. You can dilute with water a little, but keep it strong.
For shower stalls, you then rinse real good, let it dry, and then use a paste car wax on your shower stall. When you take a shower, use a squeegie after every shower to clean the walls and it will be a year before you ever see any build up again and it will remain clear and clean. When it begins to get any noticeable build-up that's not coming clean after the squeegie, simply repeat with the dishwasher liquid.
Try it...
rgatijnet1
badboy368
start with a light rubbing compound. if the spots got waxed over by some chance, they are sealed in under the wax :E
40' pusher,350 turbo cat, pullin a 37' trailer haulin a drag car. oh yea baby
USMC46
mrkoje:
First thing I tried was vinegar. It does not work on my spots. I said they were stubborn !
Jim & Carmel
2016 Escape 17b
mrkoje
I used vinegar, works like a charm.
http://www.youtube.com/watch?v=i9Zb59qO058
I'm sure it will work great for you too!
RAPTOR 300MP
RAM 3500 MEGA CTD 4X4
1BryNelson
Looking forward to the answers to this. Only way I've found is a very light rubbing compound.
Bry Nelson and a yet to be discovered MoHo momma. '99 Pace Arrow Vision 37ft F53 chassis (plugs tightened) Allure flooring, 15k BTU front a/c , 6-6 volt batts with 1120 watts of solar Magnum inverter Remote BMK Trace C40 2005 Ford Ranger "Toad on a pad".
