ZHammer
Aug 23, 2016Explorer
[Solved] Water fill leak - '95 Roadtrek 190 Versatile Dodge
Hello!
I just joined the forum and am hoping for some help.
I just got a 1995 Roadtrek 190 Versatile and pretty quickly found that the gravity fill on the water leaked something fierce.
As I was trying to fill it up, it basically rained right under the front passenger side.
I checked the levels on my meter thing too, and it went from 3/4 full all the way to empty, so it definitely isn't holding any of the water either.
I haven't fully gotten under there to check it out, but I was wondering if you all had any tips for potential problem areas that might be a likely culprit, or if there's a potentially simple fix.
Oh! The dealership I got if from said that they checked the system to make sure it was good to go and has said that it was. Based on the other effort they put into getting this ready when they didn't have to, I personally believe them on this. One of the ideas they threw out as a possibility was that they may have left a valve open when they flushed the system (i'm not sure if the leaking I'm seeing would make sense for this or not).
The RT was delivered to me in Vegas from California, so it's possible something broke on the drive.
Anyway - again, mainly looking for things I should be checking out, if possible some ideas of where to find it, etc...
Thanks in advance! Let me know if I missed anything that would help :)
