Sound insulation of doghouse
Wandering_Storm
Anybody have ideas/advice on putting sound insulation in doghouse of my 2015 fleetwood Storm. Thanks John mc donough
13 REPLIES 13
time_to_go_now
You need to see how much room you have. I replaced my 1/2" material that came from Tiffin with 2" rockwool. Then I put a 1/2" layer of fireproof material over the rockwool. I also used a gallon of roll on sound deadening material to roll about ten coats on the inside of the doghouse before I installed the insulation.
Good luck.
Jim and Deanna
2008 Tiffin Allegro 35QBA FRED
2007 Carson Trailer 22' Titan TH
Trailer Toad
Me, Wife, Boy/22, Boy/19, Girl/17
1985 Toyota 4Runner
TWO quads, THREE kids, TWO motorcycles, ONE wife, TWO dogs, ONE cat, TWO Polaris RZR's
GTN_and_Catz
Dutch_12078 wrote:
GTN_and_Catz wrote:
Dutch_12078 wrote:
On our F-53 based coach, I removed the cheesy 1/4" aluminum/foam liner that was originally installed, at least what was left of it. I replaced it with "B-Quiet Hliner", a 1/2" thick thermo/acoustic foam with a reinforced aluminum skin on both the doghouse and under the driver and passenger side floors. According to the manufacturer, "It reduces engine noise in the interior of the vehicle and also reflects the majority of the heat from the engine." My before and after sound measurements showed about a 10dB reduction at 2,000 RPM stationary. On the road, we've also found a noticeable reduction in the temperature of the dog house after several hours of travel.
Dutch,
How much 1/2" material did you order to complete the job and did you need additional adhesive to make it adhere properly?
Gene
I bought two 12.75 sq ft sheets, but one sheet got the job done, albeit I skimped a bit on the outer edges of the floors where the heat and sound have little effect anyway. Different sized dog houses will take more or less material of course. As I recall, the shipping cost was pretty reasonable, so you might order just one sheet first and see how far it goes.
If you clean the surfaces well, the self-adhesive is quite strong. Make sure of your cuts and positioning before applying it, it doesn't pull away easily to reposition it.
Mine's an F-53 as well with the same poor original aluminum/foam liner. I'll do as you suggest and start with a single sheet and see how it goes. Thanks for the input Dutch.
Gene
2003 36' Rexhall RexAir
2009 Jeep Wrangler Sahara
Demco Kar Kaddy SS
Blue Ox Aventa II
2 Ragdolls
1 Tabby
garymunson
I used the sound deadener sold by summitracing.com. Search for their Summit Racing brand...cheaper than Dynamat, seems to be the same. Has stuck well for a year now.
Dutch_12078
GTN_and_Catz wrote:
Dutch,
Gene
Dutch
2001 GBM Landau 34' Class A
GTN_and_Catz
Dutch,
Gene
Gene
Demco Kar Kaddy SS
Blue Ox Aventa II
2 Ragdolls
1 Tabby
Wandering_Storm
Chassis is Ford V10.
Gjac
Which chassis do you have? Ford or Chevy?
Wandering_Storm
Thanks to all. I installed dyna mate and the difference in noise I hard to believe. Sound reduced by a lot.
happy-2
I used DYNA MATE on my 1999 v10,what a difference with the heat and noise,
Golden_HVAC
Whatever you install, make sure that it will stand up to a flame test.
My buddy put in something on his 87 class C, and it caught fire while going to Las Vegas in June. When we got back home, we put in 1.5: air duct insulation. We gave that a flame test, a BBQ lighter flame to the product. It was not effected by the flame directly on the insulation material. It is also rated for flame spread (that it will not do it) and is rated to self extinguish in order to be installed in buildings.
He kinda freaked out when his motorhome was on fire, I just grabbed a couple of quart size water bottles and put out the flames. Then removed the doghouse, and 'insulation'. At that point, without the Ford factory insulation, it was really hot near my feet. Once back in Kentucky, I bought some header wrap, and insulated the headers where they pass near the doghouse. I also used a paint can lid to reflect away some heat, and retain the insulation between the header and doghouse where they pass each other.
In my motorhome, with a F-53 chassis (97), I have 1/2" thick foam insulation over the carpet in the drivers area. It does stop a lot of heat from going though the floor, and makes the floor much cooler. I know it would be much more effective to install some of that 1.5: air duct insulation, but something I have not gotten around to yet. . . .
Good luck,
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
Wandering_Storm
Thanks it looks like a job worth doing.
mmiille
I used metal faced sound absorbing foam in my chevy 454 doghouse.
http://www.mcmaster.com/#standard-foam-acoustical-insulation/=yal4n0
from McMaster-Carr. I used metal tape(The kind that insulators use) to hold it in.
Cut and shaped the pieces and taped them in.
Martin & Cheryl
40 Foot 2009 Damon Tuscany 4076
Cummins 360, Hyundai Santa Fe
Full timing since 2010.
Dutch_12078
Dutch
