Dakzuki
Jun 11, 2016Explorer
ron.dittmer wrote:
Baja Man,
I understand you are retrofitting your rig to accommodate a spare tire. I like your plan to mount the tire under the rig behind the rear axle. I assume you verified that you have enough room underneath and have a good place to mount the spare tire winch.
As far as tire-changing tools are concerned, I purchased a 30" long 3/4" breaker bar, a 3/4" extension for the dual rear tire lugs, and the right size 3/4" deep impact socket. The extra long 3/4" bar is strong enough to stand on if necessary. I found everything cheap for sale on the internet with cheap or free shipping.
I work on many different vehicles at an automotive charity. The best professional grade impact tools cannot loosen the worst of stubborn lug nuts on simple cars, and stubborn E350/E450 lugs would be worse yet. An extra long breaker bar is the only means to break stubborn lugs loose, and an extra long 3/4" bar will support the weight of a person standing on the end of it.
There is also another tool you can make yourself that aids in using the breaker bar. Get a piece of wood (your choice but the following will dictate the size) and set it up next to wheel of your RV. Drill a series of holes in a pattern such that the piece of wood will support the extension when torquing on the bar. Just pop the extension/socket through the hole at the right height. The will allow more energy to be expending turning lug nuts and less keeping things aligned.
38,707 PostsLatest Activity: Jan 05, 2014
