mkguitar's avatar
mkguitar
'Speriments with Coach LEDS, cheap and pleasant lighting
Stock lighting with 1156's can get hot if left on for a long time & also consume alot of power- some of my fixtures have lower rated bulbs- like in the can on the left is dim #93 bulb, and on the right an 1156.
I bought a set of 10 x 1156 socket adapters which allow use of any 12 volt bi pin LED- the set was under $18 shipped on ebay from rogerdeane.
I like Philips LEDS for durability and light quality- home depot has carried a variety and I have replaced all the bulbs in my landscaping lights with these last year and they work very well.
Prices down to about 6 bucks now.
Pic below shows 27 watt 1156 left and Philips LED right 2 watt, 195 Lumens at 3000ºK ( #9090011318)
The LED is very close in light to the 1156, a little cooler.
This is a little brighter than I like, I subbed in another LED "accent" 3G4-1 with 3 leds rated at 3 watt 170 Lumens at 2700ºK.
This is a little more pleasing to my eye for a reading light
same again, 1156 left and 3G4-1
I anticipate years of service for about $7 a hole, less power consumed ( 10%) and cooler temps in the fixtures
Mike
link to ebay item:
http://www.ebay.com/itm/10-Lot-Socket-Adapters-for-MR11-MR16-G4-Bi-Pin-to-Bayonet-BA15s-1156-Type/381507754698?_trksid=p3693.c100102.m2452&_trkparms=ao%3D1%26asc%3D20140212121249%26meid%3D34d1e97705384ab29f6e7c47bdefe742%26pid%3D100102%26
  • update again on return from a little trip.
    did some boondocking, the reduced electrical load was noticed and appreciated.
    the light intensity and quality ( colour temperature, even distribution ) was really good.
    stopped in at an "rv show" in Quartzite on my way home- about 6 vendors selling led conversion "kits" for RV's. all were more expensive and harsher lighting
    mike
  • And an update- some of the Philips 2W are a little bright- I bought some Philips 1.2 watt 105 lumen leds #454116 and am now using them in the 1st position in my 2 bulb lights.
    This is working out nicely.
    Mike
  • I've now replaced 10 incandescents with leds in the coach...with every light on- the power consumption equals less than just 1 of the old lights.
    Mike
