jvowell1's avatar
jvowell1
Spout
1996 damon intruder with 460 V8. Any idea where the spout is located to be removed to set timing?
  • It's located on the outside of the fire wall in front of the drivers feet. Look for a aluminum heat sink with the ignition module on it. The spout plug will be hanging just below the ignition module. It may be partly obscured by the radiator over flow tank.
    The spout connector is the easy part. Seeing the timing marks is a challenge.
    Richard
    95 Bounder F53
  • try this has pictures.
    https://www.google.com/?gws_rd=ssl#q=ford+460+spout+connector
  • THE SPOUT CONNECTOR IS USHALY TAPED TO WIRE HARNES BY DISTRIBUTOR OR IGN. MODULE YOU WILL KNOW ITS THE RIGHT ONE WHEN DISCONNECTED THE CHECK ENGINE LIGHT WILL COME ON
