AsheGuy
Jul 28, 2015Explorer
synergy_58 wrote:Not really. When I check for a code when there is a check engine light, I have always been able to reset the code and the check engine light then goes off. I am not at the location of our RV, so I can't take you through the sequence on the ScanGauge but when the code is on the screen it is just a matter of me hitting the reset button and then confirming that I want to reset it.
I too have the SG II, but I can't clear it. I had a 0675 code (glow plug #5) come up and stay on for about 1000 miles, the ck engine light went away, I don't have it anymore on the dash, But I can not clear it from the SG. Not sure why. ANy ides?
The ScanGauge isn't the most intuitive device in regards to user interaction. But if you get to the point where you can see the fault code, you should be at the place where the reset option is visible.
38,705 PostsLatest Activity: Jan 14, 2025
