Apr-03-2016 08:36 AM
Apr-03-2016 04:23 PM
Apr-03-2016 03:25 PM
Apr-03-2016 02:00 PM
Apr-03-2016 01:23 PM
Apr-03-2016 12:10 PM
Apr-03-2016 11:48 AM
The Works wrote:
We have been full timing for three years pulling a fifth wheel. We purchased a 2013 37' Winnibago Itasca Meridian. We have driven it for about 500 miles, it seems like I constantly need to be slightly turning/adjusting the steering wheel to keep the coach going down the center of the road. If I take my eye off the road to grab a drink the coach will drift, normally to the right. It doesn't seem to pull to the right just drift. I know its a bad comparison but while driving the one ton truck pulling a 42 foot fifth wheel I could pretty much keep one hand on the wheel and the rig would go straight down the road. My question is, since this is the only motorhome I've driven, is it normal to constantly adjusting and slightly turning the wheel to keep the thing on the road? Thanks for any useful information!
Apr-03-2016 11:47 AM
Bud
USAF Retired
Pace Arrow
Apr-03-2016 11:07 AM
Apr-03-2016 10:51 AM
Apr-03-2016 10:20 AM
Apr-03-2016 10:08 AM
Apr-03-2016 10:06 AM
enblethen wrote:
That is not normal.
I would get the rig weighed, adjust the air pressure to that specified by the tire manufacturer.
Then take it to a good alignment shop, not some tire shop.
Apr-03-2016 10:01 AM
rgatijnet1 wrote:
No, it is not normal to have to input steering corrections all of the time but driving a Class A is different from a pick up truck. Naturally the road surface can affect your steering but after 500 miles you should have experienced different road surfaces. Wheel alignment is something that should be checked as well as tire pressure to make sure that all tires are balanced. They do make a steering stabilizer that is helpful to some drivers. It looks like a shock absorber mounted sideways to to your tie rod and is adjusted to keep your coach going straight on a flat road surface.
The cheapest thing to check is your tire pressure and then I would check wheel alignment. Four wheel thrust alignment is the best, if the shop is equipped to do it. This insures that your rear axle is pushing straight to your front axle.
After all of that is checked and eliminated as a problem, you will still find that the Class A drives different than your 5th. You should be able to relax behind the wheel, however.
Apr-03-2016 09:51 AM
Apr-03-2016 09:29 AM
