- EscargotExplorer
Ray & June wrote:
"goo-gone". Works an almost every tape we've used. Sometimes you have to keep rubbing for a while, but it will clean it.
Have used Goof-Off. I found the adhesive was easier to remove by rolling a cloth over it / blotting rather than rubbing the softened adhesive.
Good luck with the macerator issue. - Roadtrekker2ExplorerDear candlback - Thanks for your help on the macerator. Would it be possible to take a couple of pictures of the system? Can you share how much it cost? I know I can't empty the tanks alone (my husband died nearly 2 years ago) because of my knee replacements and I will have to sell the RT if I can't figure out how to do that. Thank you so much.
- candlbackExplorerI have a 2002 Roadtrek and took it to an RV repair place and they were able to install plumbing and a macerator. I did modify it later, but it works good so far. My macerator is located in the long bin on the left side so it is available for jams/repair and has a hose that will extend out to the dump site. I found it much preferable to the original hose and much cleaner. I also made a hook so I can reach in under for the valve rods. (both hips have been replaced)
- Metaphor_7182ExplorerI had the a similar issue with my "new" 1997 D190V, got the same three recommendations noted above when I asked last year. :)
Found Simple Green All-Purpose Cleaner worked the best, just remember to wipe off the cleaner with a damp cloth.
No recommendations on the macerator. - Ray___JuneExplorer"goo-gone". Works an almost every tape we've used. Sometimes you have to keep rubbing for a while, but it will clean it.
- jules6ExplorerI use WD40 to remove tape and label glue
- 2oldmanExplorer II
- gerrym51Explorer III'm sure you could get it installed by someone-maybe camping world.
About Motorhome Group
38,705 PostsLatest Activity: Jan 22, 2025
