DutchmenSport wrote:
Sounds like your surge protector is doing exactly what it was designed to do.
I will second that.
OH, and though you said "Spikes" what you are seeing is not a spike, Your surge protector does protect you against Spikes but it will not shut down for a spike, Spikes traditionally last less than 1/60th of a second and are clipped by devices inside the Surge Protector since the relays can't act that fast.. And you should never notice them.. This is why i do not like most of the devices called "Surge Protectors" because they are actually SPIKE protectors.
A Surge is like a spike, but lasts longer.. I've never seen one in an RV park
A "Brownout" is long term reduction in voltage (Long term means more than 1/30th of a second, or longer depending on the programmer). and this too the Surge Guard (note the lack of quotes) will protect against.. This is more than likely what you are seeing, A park with anemic wiring is "Browning out" as various A/C's kick in and taking the voltage too low. Often your device will report the cause of the disconnect but you may need to be looking when it happens.
They also respond to over/under frequency. but this is very very rare when hooked to mains and would indicate major issues and likely result in the fire Dept paying a call on the power company.
