I've been considering a tankless water heater for my RV as well. I've heard they can be more efficient and provide endless hot water, which would be great for longer showers or washing dishes. I'm curious to know what brand and model you installed on your boat, and if you had any issues with the installation or operation.
One thing to consider is that tankless water heaters require a higher flow rate than traditional tank models. This means you may need to upgrade your water pump or add a booster pump to ensure you have enough water pressure. Additionally, tankless water heaters can be more expensive than traditional models, so it's important to weigh the pros and cons before making a decision.
If you're considering a tankless water heater for your RV, I would recommend doing some research to find a model that is compatible with your RV's water system. You should also consult with a qualified RV technician to ensure that the installation is done correctly.
Overall, I think tankless water heaters can be a great option for RVers who are looking for an efficient and convenient way to get hot water. However, it's important to do your research and make sure that a tankless water heater is the right choice for your RV.
