Tire pressure
aboeck3
Tire pressure question. My tires are Michelin 275/80R XZA3 LRH. They are on a 2017 Winnebago Journey 42. The Michelin TP chart says max air pressure is 120 psi. My question is what pressures would you all recommend as a safe, comfortable pressure to keep these tires at? 120 psi seems high for a nice ride.
Al & Jane - RETIRED
(Nico, Smudge & Boo - Cocker Spaniels)
2017 Winnebago Journey 42E with 2013 Honda CR-V toad & 2 bicycles (just in case)
Dreams Do Come True
12 REPLIES 12
4x4van
As Ivylog says, look for the Federal Tire Placard near the driver's seat. Use the pressures listed there, NOT the max pressures listed on the tire sidewall. Keep in mind that the Placard assumes that you are at your max GAWRs. You should never run a higher pressure than that, because you should never load your rig heavier than that.
As soon as is practical, get your rig weighed, 4-corner is best, but front/rear will suffice. Then use the pressures that the tire manufacturer recommends based on the actual weights.
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
Executive45
I run 115 steer 100 drive 90 tag. Tire size - 315 steer and all others are 295s. All Michelin. PSI is based on my axle weights...YMMV...Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
Monaco Executive M-45PBQ Quad Slide
525HP Cummins ISM 6 Spd Allison
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
Ivylog
There should be chart next to the drivers seat...start there until you weigh at least each axle at a truck stop. Educated guess, 115 front, 105 drive, and 85 tag.
Upgraded with a 08 HR Navigator 45โ€™...
darsben1
Short answer is leave them at max unless you are willing to do the work
Traveling with my best friend, my wife in a 1990 Southwind
roam1
weigh it, use chart, + 5#
Bill_Satellite
It is impossible to answer this question until you have weighed ALL 4 CORNERS of your coach. You can get a rough guess by weighing front and rear axles but you could still be dangerously wrong without accurate information. Once you have the corner weights you will be able to look at the Michelin weight tables to determine the proper inflation.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
johnsonbert
Here is the link to the Michelin inflation tables, just choose your tire diameter at the top of the tables. Weigh your rig, loaded, and then use the tables to determine the tire pressure to run, by weight. 4 corner weight is the best, but axle weight will do, divided by number of tires on axle, at any truck scale. I usually add about 5 lbs for a little extra cushion. Hope this may help, Happy Trails Bert
Michelin tire inflation chart
2006 Monaco Dynasty Diamond IV 42' Tag, ISL 400,(new to us), Residential Refrig, 10KW Onan, Bosch Washer/220V Dryer (previously 2003 American Tradition 40W) 2010 Chev Malibu LT
jplante4
Max sidewall will be safe until you have the coach weighed with all of your normal traveling accoutrement aboard. Then use the manufacturer's chart for you weight.
I ran 125 psi on the Yokohamas until I got weighed at 22,000 lbs and found I could drop to 90 psi. I added 5 for a buffer. Made a big difference in the ride.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
Leeblev
Those are my front tires. Since they are Michelin, they are very comfortable at 120 psi. Any other tire may not ride as smooth. I keep my tires at the recommended pressure because you WILL get better mileage when you inflate according to the MFG recommendations. I have never had a problem when my tires are properly inflated. I haven't, but I would sacrifice comfort for mileage.
Lee
2001 36' Kountry Star DP
Mandalay_Parr
Pressures are based on weight.
Need to weigh the coach fully loaded.
Four corners if possible. Otherwise each axle.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
Lwiddis
"120 psi seems high for a nice ride". To me also but not being a tire manufacturer I dont know. What does your RV manufacture say in your owner's booklet?
K_Charles
Weigh it and then put in the proper amount according to the chart
