^What he said.
Without knowing what size tires are on it and how loaded down it is, none of us can say.
The tire kid may be right. And heโs certainly not grossly incorrect for the front axle. Unless youโre somehow loaded @ss heavy, 80psi on pizza cutters up front is ok.
Rear, same thing, although at 12.5k gvwr youโre probably 7500 +\- on the rears. 65 psi would be the minimum except in hot weather/high speed high duty cycle Iโd want to be wired up more.
Or if youโre running in real cold weather and/or snow Iโd want to be a tad on the low side of โperfectโ for traction purposes.
That said 80psi isnโt grossly over pressure in the rears for that rig unless itโs basically empty. And even then it wonโt hurt a thing or tire wear. Just ride a little more harsh.
2016 Ram 2500, MotorOps.ca EFIlive tuned, 5โ turbo back, 6" lift on 37s
