Tire Rotation
Pops_R
Not having any luck finding a Camping World that can do tire rotations on the Motor Home as we travel. So my question is where is everyone else getting there Motor Home tires rotated? Then if a general ball park quote on what is being charged for this service would be great.
30 REPLIES 30
Ductape
Google is your friend. Why not take direction from your chassis and tire makers?
Many recommendations here will differ. For most MH owners the tires get old before they wear out. If you are in the minority who will wear out the tread then rotation can extend tread life.
49 States, 6 Provinces, 2 Territories...
tropical36
Easy question. Don't rotate your tires. We never do.
If you must, a truck tire shop shouldn't be that hard to find and have even had tires installed in the lot and in a grassy lot behind their shop, when without a truck bay.
Ohio_Engineer
The OP didn't identify a problem with the current tires. It is my understanding that on Class-A rotation is not needed unless you are trying to even out some irregular wear that developed (probably due to an alignment issue)
The "don't change direction of rotation" was a solution looking for a problem 40 - 50 years ago when the tire industry was first learning how to build radials. Since the belts go in both directions (up to right and up to left) one belt is always running "into" the footprint no matter the direction. The early problems that I saw was the tread splice opening up when it wasn't properly and completely cured closed. The idea was that one direction would tend to keep the splice closed and the opposite might tend to make it open.
Engineers have learned that the "Tread Separations" that were being reported were actually belt separations due to improper (low) inflation , overload and excess heat.
I would think of it more like the 3,000 mi oil change that has been replaced by 5,000+ miles and even computer monitored change schedule.
Technology has moved on and the weakness at the tread splice area is no longer an issue for the top tier tire companies.
Given that most Class-A will age out before they wear out I see no reason to spend the time and money doing a rotation based on decade old ideas.
Now if someone wants to rotate or not rotate their tires that's up to them but as an engineer I trust facts and data way more than the opinion of individuals or even companies that have not tested a few hundred thousand tires.
DSDP_Don
Like I said, your coach, your money and your destroyed fenders. This is especially true on a tire that may have cupped and is being moved to another position and the rotation direction being changed. Just because you didn't have a tire that separated, doesn't mean it won't happen. Many keep their tires for 10 -12 years. It's all about the risk you're willing to take.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
Canadian_Rainbi
mpierce wrote:
DSDP Don wrote:
Canadian Rainbirds wrote:
That has not been true for radial tires for decades. It was a concern in the early days.
You're absolutely right that it doesn't apply anymore to PASSENGER CAR tires, but you'll most likely cause tread separation on large RV tires, especially models like the Goodyear G670. I never change direction on any tire, personal preference, but I would never change direction on a large RV tire and take the chance that the tread separates and causes a blow out. Your RV, your choice.....change tread direction if you like!
I would think RV tires would be the same as truck tires??? On my Peterbilt, I rotate the fronts from side to side once in their 250,000 mile life. I also rotate the rear tandems. On them I swap the RF to LR, the LF to the RR. I leave the outside tires on the outside, because the wheels are polished on one side, and I do not have to remove tires from the wheels this way.
This is the method, told to me by several truck tire shops, that is reccommended. This changes direction of rotation of all the tires. Never had a problem, and it is the suggested rotation method by truck tire shops.
And my last set of Michelin 235/80R 22.5 XRVs were replaced after 5 years and 139,000 kilometers (86,400 miles). There was still usable tread left but we were getting ready for a 15,000 Km trip, much of it to be in Mexico where XRV tires are not available.
All 6 wheels are identical.
bluwtr49
Rotating tires can be difficult since you most often need to dismount the tires to do so.....different wheels between the steer and drive axles. Tag may be the same as steer but that may differ between coaches.
Dick
2002 43' DP Beaver Marquis Emerald Cat C-12 505 HP, 1600 Tq
2003 Jeep Grand Cherokee Overland ---toad
Sam_Spade
The thing is............
For me and I suspect most RV'ers, my tires will expire from old age WAY before they come anywhere close to actually wearing out the tread. If you are a low mileage user AND you see abnormal wear, then something is drastically wrong and needs to be fixed. Rotation is a waste of time and money for a low mileage user.
Now if you are a high mileage user, like you wear off the tread in a couple of years, that might be a different story.....but I doubt it.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
mpierce
RayChez
I never have had uneven tire wear, so I just leave them alone. I change tires every five or six years and the thread still looks new. So why mess with something that is not needed.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar 3126-E
3000 Allison Transmission
Neway Freightliner chassis
2017 Buick Envision
DSDP_Don
Don & Mary
Houston_Remodel
If you live near a Discount Tire -
Take your less-than-one-month-old RV, TV, trailer (or buy new tires there) and get the road hazard warranty. Discount tire will warranty any tire they didn't sell as long as you bring in the veehicle soon after purchase.
Included in the warranty is free tire rotation.
I am horrible with tires. Once owned a tire for 6 hours before ripping a huge hole in the side. Took my demo trailer in one day. They saw the dry rot and sold me 5 new tires, installed, for $45.
The downsides - they aren't open on Sunday and are generally only in the south.
2015 Starcraft Launch 24RLS
2014 Ram 2500 diesel 4x4
Guarded by 2 Jack Russells
mpierce
Truck tire shop. On my Peterbilt, I rotate the front tires by swapping them side to side. Rotation direction does NOT matter.
Dale_Traveling
Truck tire shop. You could call your roadside service provider and ask who they would send to your home if you had a flat tire in the driveway. Will give you a quick starting point in your local area.
A truck tire shop might also have the heavy equipment to perform alignment and other chassis related service you might need down the road. Very beneficial to find the local service providers other than RV service centers for chassis related help. Save the RV places for strictly RV stuff that needs attention. Work with the strengths of potential service providers and what they do day in and day out.
Simple general rule - above the floor RV service center, below the floor medium or heavy duty truck service center.
2006 Hurricane 31D built on a 2006 Ford F53
obgraham
MrWizard wrote:
on a (6) tire coach you don't rotate the tires
We've been discussing this elsewhere in regard to Class B's with dual rears. Since the inners are on steel wheels and the outers + fronts are on alloys, a true complete rotation would require dismounting and remounting, to the tune of about $250 per time.
Most all conclude that it's not cost effective as the tires will age out before they wear out, so we'll apply that saved $250 toward new tires down the way.
