โJan-29-2016 07:59 AM
โJan-29-2016 08:47 PM
โJan-29-2016 05:19 PM
โJan-29-2016 05:05 PM
Canadian Rainbirds wrote:
We rotate ours once a year: left rear swap with fronts, then next time, right rear swaps with fronts etc.
โJan-29-2016 04:14 PM
โJan-29-2016 04:11 PM
DSDP Don wrote:
Pops, most people don't rotate the tires on a coach like yours. You never want to change the direction of travel on a radial (fronts) and you need to keep the rears matched to their original partner. It can be done, but is not cost effective. Keep a close eye on your front tires making sure the air, alignment and balance are correct. Typically, they will need replacement first, but you can then break up the cost of tire replacement over a couple of years.
I've owned a dual rear wheel coach of some kind or another for over 24 years. Last year was the first time I was able to rotate the fronts to the tag position on my coach (my first tag axle RV). Obviously this doesn't pertain to your coach, but shows probably the only time the fronts can be moved around without costing a fortune and changing the direction of travel.
โJan-29-2016 02:38 PM
โJan-29-2016 02:25 PM
โJan-29-2016 01:27 PM
โJan-29-2016 01:19 PM
J-Rooster wrote:ArchHoagland wrote:X-2!
I never rotate my tires on my motorhome.
Not recommended.
โJan-29-2016 01:07 PM
โJan-29-2016 12:59 PM
Not recommended.
โJan-29-2016 10:08 AM
โJan-29-2016 09:57 AM
โJan-29-2016 09:13 AM
โJan-29-2016 09:06 AM
