Mybackyard's avatar
Mybackyard
Toad Questions
We just purchased a 1998 Winnebago Chieftain. We were hoping to tow our Jeep Wrangler along with us. I was reading the owners manual and it states that we can only tow 3500lbs. The Jeep is above this. Is there anything that I can do or do I have to start shopping for a new toad?
1 Reply
    your winny likely has a Class II hitch which is limited to 3500-lbs but your towing weight might actually be less. consider...in general, the maximum amount of weight you can safely tow will be the lesser of the following:
    - the GCWR (gross combination weight rating) of the MH minus the actual weight of the MH as it is loaded for travel (includes fuel, fresh water, food, clothing, people, pets, supplies, etc.)
    - the weight rating of your tow bar
    - the weight rating of your hitch
    this is why it's vital to know what your MH weighs (by axle) as it is loaded and configure for travel before choosing a toad. Your MH will not collapse if it is overloaded but you will experience handling issues as well as longer braking distances and accelerated wear on suspension, brakes, steering, etc.
