May-27-2013 06:04 AM
May-31-2013 02:20 AM
May-31-2013 01:32 AM
May-30-2013 10:59 PM
merleandbabe wrote:
Flat towing a 2007 Honda Civic, with no problems except one.
The running lights stay on and the battery goes dead after about two hours.
Any ideas..on how to prevent this? The ignition must stay in accessories potion, and in neutral.
I have heard of a tow charge? How much
Thank you
May-30-2013 07:56 PM
brick wrote:
How old is car battery? Maybe the easy way to fix problem.
May-30-2013 07:05 PM
May-28-2013 03:10 AM
May-28-2013 02:29 AM
May-27-2013 07:57 PM
May-27-2013 01:53 PM
May-27-2013 08:28 AM
wa8yxm wrote:
What are you using for the aux brake system.. The US-Gear Unified Brake Decelerator system includes a link between the coach battery (Chassis) and the towed, Heavy wire breakerd at 20 amps (Coach) and 40 (Towed).
Invisible brake (Roadmaster?) also has a charge provision.
The Towed charge system above with other brake systemns.
Second, there should be a fuse or two you pull, or you remove the fuse, install a way overpriced adapter (like 50 bucks) with leads and a switch, and plug the fuse into the adapter.. Flip the switch and it cust off the battery killers.
The running lights should NOT come on in the accessory position.
May-27-2013 08:16 AM
May-27-2013 07:26 AM
May-27-2013 07:22 AM
May-27-2013 06:15 AM
