towing strain
mccoydetlef
How much of a strain to tow a2008 Saturn vue behind a 1995 class a 35 ft 460 ford unit only has 28k and is perfect. Is it worth it to tow without putting a strain on it THANKS
1998 BETTY BOOP AMERICAN TRADITION
22 REPLIES 22
FormerBiker
What no one had mentioned is that if you go the go, you must have the whoa.
Braking is also considered in a max GCVW rating. Even though you will most likely have aux. brake system such as brake buddy, stopping the rig will be interesting if it fails. Stay within the manufacturer's weight restrictions.
mowermech
Trumpet Player wrote:
mowermech wrote:
I used to have a Jeep Wrangler Rubicon Unlimited, slightly modified.
I towed it with a Tioga Class C on a F350 chassis, 460 engine. I had a local welder reinforce the hitch. We went over the Continental Divide several times, no problem. As I have said, nothing bent, nothing broke, nobody was injured or died.
Then we got the coach in my sig. Again, no problems.
Then I got rid of the Jeep and bought a 2001 Dodge Ram 1500 quad cab short box. We towed it, using a Roadmaster Stowmaster towbar. Again, no problems.
Then I wanted better towing capability, so I got the truck in my sig. I jhaven't tried towing it, because it weighs 7900 lbs. empty, and the Stowmaster is only rated for 6000 lbs.
If that was my rig described in the OP, I would have a known qualified fabrication welder inspect the frame rails and the hitch to see if it can be upgraded to tow the load, then allow him (or her) to do the upgrade.
Interesting... How does a welder/fabricator "upgrade" the "tow load" or technically stated the certifications or ratings? Answer... they can't!
Well, actually, YES, a properly certified upfitter shop CAN change the certified ratings! However, I wasn't concerned about the "ratings", I was only concerned with getting the job done, safely. we accomplished that. the modified hitch towed the load just fine. Again, nothing bent, nothing broke, nobody was injured or died.
Success beats the numbers, and I normally refuse to play the "WHAT IF" game.
CM1, USN (RET)
2017 Jayco TT
Daily Driver: '14 Subaru Outback
1998 Dodge QC LWB, Cummins, 5 speed, 4X2
2 Kawasaki Brute Force 750 ATVs.
Pride Raptor 3 wheeled off-road capable mobility scooter
"When seconds count, help is only minutes away!"
tropical36
Follow some of the advice here and do the numbers to be safe.
May want to have the hitch strengthened some and be sure to install toad braking. Knowing how to handle down hill descents are usually the problem for some and not with climbing mountains.
Strains are usually on the transmission if they're going to be anywhere.
Having said this and with a 98 gasser, we pulled a ton over specs. and for years, all over the US, with no ill effects, other than making some allowances for long 6% grades. Again it was with the 4L80E GM transmission for being the weak link. Your Ford tranny, should have a much better rating.
ferndaleflyer
Looks to me like according to the experts here you can't tow---they don't even understand up grading the hitch-----No hitch weight involved to amount to anything and if the frame and hitch are adequate hook up and go. Look for reasons to do things not reasons not to, you will get more done.
mccoydetlef
or looking one for sale with hitch that goes on class 3 hitch any ideas
mccoydetlef
ok now help me how about a scooter or motorcycle with a tow hitch
Trumpet_Player
2012 American Coach Revolution
tropical36
Most likely with the Ford chassis, you're good with the GCVW rating, unless you're grossly overloaded with your GVWR, now.
Then there's the hitch, itself, which is most likely 3500 or 5000lb and if you tow 4 down the hitch weight rating doesn't come in to play at all. So now, how much does the coach, fully loaded and then, the car weigh for doing the math. I weigh ours at the truck stations along the interstate, at no charge and nary a problem ever, when they're not busy with trucks lined up.
All these ratings should be on a closet door in the coach somewhere and even though I don't advocate it, there's a lot of leeway to be had with weights and measures and if some overloading was a real factor, then that's all you'd hear about among these forums, with so many leaving the driveway overloaded on a daily basis.
We pulled a ton over specs. all over the country with our old gasser on a Chevy chassis, but the only weak link was the 4L80E GM transmission, so one had to be diligent when climbing long 6% grades in high ambient temps. Even at that, it would just go into limp mode for saving itself and proceeding in low gear at 25mph max. gave another 25% in the rating, so it never became a real problem.
cooper841
I would also check to see how well tyranny cooler works. Some of the old tyranny gears wasn't that great.My first hand info.
Dana Cooper
Chipper(Lab)
2007 Fleetwood Fiesta LX
2003 Harley Fatboy mighty hauler lift
2010 Kia Soul
mccoydetlef
Thanks will pay attention to all very good
Bikeboy57
You have already read replies that give you the weight ratings. You have heard from people that say it can be done even though the weight rating is exceeded. Will it damage the motorhome? Probably not.
But no one has discussed the legal implications. In our litigation happy society pray that you do not have an accident and injure someone with an overweight tow vehicle behind the RV. Takes an accident specialist attorney about 60 seconds to look up your rig and the tow vehicle to find your legal vulnerabilities
Richard and Rhonda
1999 Newell
Subaru Outback toad
JoeH
You should not have a problem.... think about what it takes to push the car by hand ( once you get it going)... doesn't really take that much effort. I've towed with a 1978 MH on a P30, 454 Chevy, A ford F53 and my current Dutch Star.
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
mccoydetlef
ok how about 2011 HHR that will work RITE
Dutch_12078
I'll just add that we towed a ~3500 lb Toyota RAV4 automatic 4WD with a 1995 34' Coachmen Class A on an F53 chassis powered by a 460 V8 for about 5 years and ~30,000 miles with no problems.
Dutch
2001 GBM Landau 34' Class A
