- PCarnathanExplorerWe found there would be a sewer smell inside the rig immediately after dumping the tanks, despite rinsing and using the holding tank treatment. We bought these vents and we haven't had any odor since.
Camco 40595 White Cyclone Sewer Plumbing Vent
Pat in Menifee, CA - filrupmarkExplorer
gbopp wrote:
Check the air admittance valves under your sinks.
Replace with Oatey brand from Home Depot. Very easy ,worked great for us. - SkiingSixPackExplorerWe had what we thought was a sewer smell coming from our MH. It turned out to be our house battery boiling because of a bad electrical controller. It smelled very similar to a black or grey tank smell. Just something to check. Good luck!
- Executive45Explorer IIIMy 2 cents worth.
1.Empty P trap at Washer/Dryer.
2.Plugged vent pipe...
....Dennis - CVDExplorer
coolmom42 wrote:
Could be:
a plugged tank vent
air admittance valves under the sinks leaking
toilet leaking around the base
batteries off-gassing excessively
Re. to check #3 on this list, confirm your toilet holds water for at least a day. If not change the ball gasket, easy fix. - newman_fulltimeExplorer IIwhat kind of waste smell :h
- ksg5000Explorer IIMake sure you have water in all the p traps (sinks, showers etc), replace the check vale/air admittance valves under the sinks (inexpensive), run water down the roof black/gray vents to insure they are clear. Clean the black/gray tanks. If that doesn't fix then consider replacing the toilet sealing ring.
Sometimes the vent pipes will drop from their proper position into the tanks which means they no longer vent properly - doesn't happen often but it does happen. - coolmom42Explorer IICould be:
a plugged tank vent
batteries off-gassing excessively - bdpreeceExplorer IINot enough information. Parked, on the road, certain area in the coach, windows open/closed, after dumping, etc. Verify that it is not coming from your battery compartment as a battery off gassing smells like sewer gas.
- gboppExplorerCheck the air admittance valves under your sinks.
About Motorhome Group
38,766 PostsLatest Activity: Jan 10, 2026
