chast
May 05, 2016Explorer II
Water pump/no pressure?
Hi all--'97 RT170P. All was well with the water system until I decided to install an anode rod. Now when I turn on the pump, it runs and water flows, but it will not built pressure (taps off) and shut off. I have checked to see the water heater is full (pressure relief valve) and the pump sounds normal (pumping water) but then goes quiet and keeps running. I suspect air in the lines but can't get the pump to build pressure and shut off. What gives?
