Thanks all--problem solved. Tried hooking up to city water and letting pump run--no effect. Pump would begin to make a "throaty" sound like it was picking up water then continue to run without building pressure and shutting off. Although I had plenty of water in the tank, I filled it completely, turned on the pump, let the taps run for a few minutes, shut the taps and viola'--problem solved. Pump picked up the prime, built pressure and shut off like it is supposed to. Thanks all for your input.
chartrue2@aol.com
