Water Pump Ran Dry
jeffo
I drained my fresh water tank and forgot to turn off the pump. Might have ran dry for almost a day before I found it. It still pumps but I was wondering how much damage I did.
2013 Thor Daybreak 32HD
10 REPLIES 10
jeffo
Thanks, and I thought I was the only one to ever do this!!??
Effy
Mine ran dry for a few hours once. Didn't notice it until it didn't work and turns out it blew the fuse.
2013 ACE 29.2
dougrainer
The RV water pumps have a Thermal overload built in. They will run until the motor temp kicks the motor off and once it cools down will run again, so the pump rarely runs full time when the tank is empty. This helps prevent pump failure. But letting this go for days or weeks will destroy the pump unless you have no shore power and the battery eventually goes dead. Doug
ArchHoagland
Funny I was just thinking about that today.
Several years ago mine ran for a good 24 hours and I figured it would destroy it.
Runs great to this day.
You'll probably be OK.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
drifterpilot
Well, that's interesting and good to know. I have wondered about that.
2017 Allegro 34P
7,900 Miles, Ford V10
Winegard (in-motion tracking)
Blue Ox Avail
Brake Buddy
dieseltruckdriv
I ran my Shurflo for a day and a half with no water, over two years ago.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
ScottG
Mine ran dry for more than two days and it's in a confined area. It was warm to the touch (just warm) and has continued to work perfectly during the five years since.
stugpanzer
I don't think the pumps will be damaged running dry. Now running it for a full day under any circumstance will take how ever many hours of the life of that pump I would imagine!
I just installed a Flojet Sensor VSD 4.5GPM Pump.
Here's a pic of the box:
Now, this is the owners manual. Notice bullet item #7 - Self priming / Runs Dry:
2006 Fleetwood Pace Arrow 37C
Mods: EEZRV Products TPMS, Cobra 29LX 50th Anniversary CB radio with Firestik NGP Antenna, Self contained sewer hose
Old-Biscuit
None.
They are a diaphragm pump.
Diaphragms move very little----1/8" travel
They do not rely on water for cooling or lubrication
Look up mfg. and they will state 'designed to run dry' or similar
Daveinet
none
The pump is most likely the rubber bellows type. Since it is just rubber flexing, it does not hurt it to run dry. OK, maybe you consumed some of its life just because of the hours put on it, but no specific damage for it running continuously.
IRV2
