What did you do to your Class A MH today???
Rich_Panganiban
This is always a fun thread to watch, so I thought I would start one here.
2007 Jayco Greyhawk - Kodiak 32SS
'00 Subaru Outback Wagon
5,655 REPLIES 5,655
Useroverdrive
Registered my account at rv.net. I'm also testing some winter modifications by running an electric heater all day. So far so good
xctraveler
Here is a catch up post. When I brought the coach out of storage in September I noted a failed wiper seal on the passenger side front slideout. For a variety of reasons including travel with grandson and personal travel overseas this did not get dealt with until the end of January (the coach was back in storage October through December). We resumed living aboard on January 3 and within the week we went through very cold temps in Northern VA (as low as 4 overnight). I did not note any failures as a result of the cold, AT THAT TIME.
In Florida the Precision Temp tankless water heater began spewing water through the flow gauge face. Diagnosis from Gary at PT, the freeze preventer had turned on as called for, but failed to turn off, a known issue, overheating the flow gauge and causing it to distort. With his guidance I took the flow gauge apart and reassembled it which eliminated the immediate issue of no water in the coach (heater bypass valve is useless), however the spraying water had taken out the gas control board. Precision Temp shipped me both required parts no charge! Since I was having the seal (from the first paragraph)repaired at La Mesa in Sanford, I elected to have them install the new card and replace the suspect flow gauge.
While waiting for the parts,the water system started throwing black sand into every filter and screen on the coach. Diagnoses by me, the house filter had been damaged by the freeze back a month prior and was adding its carbon to the water flow. Simple project to replace the filter and clear the strainers on all the sinks. Unfortunately the kitchen sink did not clear as easily. The stuff had clogged the diverter valve for the spray hose. I crawled under the sink and tried to clean the diverter as recommended on the Pfister web site. It got better but not good enough. Talked to their tech and they sent out new diverter and new faucet core, no charge, lifetime warranty! I crawled back under the sink and replaced the diverter (2 minute job the second time). La Mesa installed the rest of the parts AND the seal and we were off to chilly Alabama, Summerdale that is, where I have washed the coach, finally, changed out the battery on one of my TPMS sensors and added a ROKU box to my entertainment options.
Sorry about the long list, hmmm... sorry it was so long ๐Ÿ˜ž but we're having fun.
Paul
2012 Phaeton 36QSH on Freightliner Chassis with a Cummins 380 pushing it. 2011 Cherry Red Jeep Wrangler Rubicon with US Gear Unified Tow Brake System. Check out my blog
FMCA 352081 SKP# 99526
revump
A great experience at Camping World in San Bernardino, CA. I had them install a Voyager Tri-View Backup System = works great ... Service and clean our Splendide 2000 Washer/Dryer ... install drip rail over windshield
Bob
mikeintn
"After camping in a couple of situations where it was sort of "close quarters" over the last couple of years, it has been determined that I should have had "Genturi" long before now. It's not only common courtesy but, it's a lot healthier in terms of anyone that close to your rig, to not have to breath that exhaust if you happen to be camped that close to each other."
Good Job! It looks nice and should work well. I made one out of light weight PVC pipe that works well, we use it at NASCAR races where we are crammed together sometimes and never had an issue. You will get some detractors here because yours is not the store bought kind, but ignore them. Nice pictures too ๐Ÿ˜„
Mike, Cindy, Chris and Spunky the Cocker Spaniel & Naro the cat
2002 Holiday Rambler Endeavor 38 PST
Cummings 330
Onan 7500 Watt Generator
Master Tow 80THD tow dolly
2009 Mini Cooper S Toad
FIRE_UP
Gents,
Well, I saw them at Quartzsite for $119.00 total. I pondered it for a day and, when a friend came back to camp with one, I thought I'd go pick one up the next day. Well, the old fraise, "You snooze, you loose", yep, it applied to me and they were all sold out.
So, back at home and check Camping World and a couple of other sights and, they hovered around $130.00 and up, and some added shipping. So, I snooped around on the net and found out there's been quite a few of you that have made them yourselves.
So, I looked any pictures that were displayed and thought, heck, if I can pull the radiator out of this big beast, if I can disassemble 3/4 of a 7.5QD generator for a sensor/rotor/head gasket replacement, if I can install a Hydralift motorcycle carrier/lift on the back, I CAN BUILD A GENTURI!!!
So, off to Home Depot for an 1 1/2" EMT elbow, and some sort of light weight 3" tubing. The rest of the paraphernalia for constructing this little project I figured I had laying around someplace. Well, regular PVC 3" tubing and, ABS 3" black tubing was just too darn heavy. I went out to the garden department and found some light weight, plastic 3" drain pipe but, it was white and none of them were real straight.
So, while wandering around in the store, I happened upon the rain gutter section. And low and behold, there was some "down spout" tubing that was white and, some was brown. I picked up a 10' section of the brown and it was incredibly light. So, my brain started straining to come up with a plan for utilization of this rectangular stuff as opposed to using the larger, 3" round stuff, if I could find any I liked.
Well, I came up with Plan A and, headed out the door with one stick of brown down spout, a couple of support clamps and, a couple of extension connectors and the EMT elbow. I got home and went to work. The first thing I had to do was cut a "V-notch" in the center of the EMT elbow and put just a tiny "kink" in the bend to get it to bend straight up. Then I had to cut a couple of slits into the one end so a regular 1 1/2" inch muffler clamp would clamp that EMT bend to the stock exhaust pipe of the gen.
Then came the formation of the double bend brackets that transitioned the EMT elbow to one of the coupler/extensions. As you can see in the pic, I didn't just pop rivet to the coupler. I "sandwiched" the coupler with small pieces of aluminum and then, attached each double-bend bracket to that aluminum. I did that for one main reason. I figured pop riveting just to the thin plastic of one of those couplers would not last all that long and vibration etc. would get to it and I'd have crack appearing soon after it went into service.
So, it was just a tad bit more work to fab up all those little pieces of aluminum but, it made a serious difference in the stoutness of the setup. Once that was done, then I installed it on the coach/gen exhaust pipe. Now, to lower the long stick of down spout into that coupler. The connection is great. Now, I need some stabilization, about half way up that pipe. Hmmmm, what to use? I was thinking of running down to Harbor Freight to pick up some suction cups that I'd seen in another home built genturi. But, DING! A light bulb just popped on in the old brain.
I've got a "Go Pro" camera that I use for motor cycle rides and other actions sports. It came with a suction cup and a mounting arm. So, I retrieved that suction cup and stuck it to the side of the rig, at the highest point I could. Now, all that's needed was something to adapt it to the upright pipe.
Well, about 10 minutes of "MacGyvering" and, DONE! Well, it was all done and mounted. Now, for the true test, will it work? Zoom, the generator started. The home made genturi is as stable as a rock. There's no movement what so ever.
I got out my trusty infra-red heat gun and checked the temp of that plastic tubing etc. at various time and distances up the pipe. The highest the temp ever got, after about 20 minutes to a half hour with no load, was about 120 degrees. I could put my hand on that down spout anywhere and not burn my hand. It had no signs of getting soft from being too hot.
Since I found no real specs on just how far away from the tubing the exhaust tip should be to create the venture effect, I just "Winged" it. I got about a 5/8" gap. When I first fired the gen up, since I don't smoke, I needed something to tell me if a "venture" was actually being created. So, off to the paper towel rack and, a butane lighter was obtained.
I lit the paper towel on the corner and let it get going a bit. Then I blew it out and of course, it was smoldering. I held that smoldering section close to the venture area and wow, it sucked that smoke right up. I was happy.
So, for about $20-$25, I got a perfectly working "Genturi". That of course does not include the spare aluminum I had laying around and, the 1 1/2" muffler clamp I already had and, the Go Pro camera suction cup mount. Take a look at the pics and see what you think.
Scott
Scott and Karla
SDFD RETIRED
KI60ND
mikeintn
With 5-7 inches of snow predicted with some ice and heavy snow, I semi brought the MH out of winter slumber to top the gas tank off for running the generator and staying in the MH if the power goes out. Plenty of propane and plenty of fuel now, bring on the snow!
Cummings 330
Hank_MI
After plowing 6" of snow off the driveway I installed a new starter on the engine. The plan is to head to FL next week. Yesterday the roads were all cleaned up from the snow on the weekend. Decided to go fuel it up, park it close to the garage doors so we could start loading up things that won't freeze. No, start, just a click. It's a brand new, 1 week old, 1000 CA, 800 CCA battery and the volt gauge dropped down to 9 when trying to start. Hit the AUX start switch to jump the house batteries over, same thing. Put in another fully charged battery, same thing.
So I pulled the starter yesterday, got a new one and put it in today. Started right up. So if there are no major snow storms next week we're back on track. Over 70" of snow here this winter and no warm days to melt it. I'm more than ready to get out here.
Canadian_Rainbi
aboeck3 wrote:
Started "re-stocking" new coach. starting fromscratch putting everything in the right place (at least once). Planning next trip
Unless DW was in charge of stowage, everything will NOT be in the right place! :B
Koop
New faucet in the kitchen. Removing the old Moen was the hardest part. Took about an hour. Installing the new Delta took about 15 minutes.
Mike
2003 Alpine Coach 40MDTS
400HP Cummins ISL
aboeck3
Al & Jane - RETIRED
(Nico, Smudge & Boo - Cocker Spaniels)
2017 Winnebago Journey 42E with 2013 Honda CR-V toad & 2 bicycles (just in case)
Dreams Do Come True
Canadian_Rainbi
FIRE UP wrote:
Well gents,
I just completed another project. My basement A/C unit was making one heck of a racket while running. It's been getting a tad worse as time went on. We have an '04 Itasca Horizon 36GD with the C-7 330HP CAT and, the basement A/Cs in those Winnies and Itascas have been know for this issue. What I did was remove the A/C unit, set it on some saw horses, alongside the coach and then, remove the top of the unit to find that, on the outside fan, (a squirlcage unit) they used a bronze bushing instead of a bearing.
Well, a trip to Graingers remedied that with a new, Pillow block sealed bearing. Much quieter now. While I had that A/C unit out, I gained access to some very important electrical components. As you'll see in the pics, they were in quite sad shape. What I found out was, they all had to do with the starting system of that CAT. And, they're impossible to get at, with that A/C unit, mounted in its cubby hole.
So, I took that whole system apart, cleaned all the cable ends and installed a new:
135 amp, automatic reset, circuit breaker
250 amp, Bussman, fuse holder
Remote start, solenoid/coil.
The big beast started pretty good before this work but, it spins over considerable better now. And, you'll see why in the pics. So, my point here is, if any of you have a similar situation, do get in there and take a look and see what kind of condition your system is in. It is impossible, on that coach, (and possibly many more of the same vintage, make and model) to do any service on that system, with the A/C unit in place.
Scott
Nice work. We had to pull ours last year to replace a compressor while in Mexico last year. NOT an easy job on the '02 32' Itasca with the Cummins.
FIRE_UP
Well gents,
Scott
Scott and Karla
SDFD RETIRED
KI60ND
FIRE_UP
Trap wrote:
Washed and polished one wheel, will try and do one more today. Polishing Aluminum rims is not something I want to get done in one day. At this rate it will take me most of next week to get done;)
Trap,
Polishing rims IS a pain and, an art. I've been polishing aluminum since I was a pup. Yep, it does take time. I've done mine "On and off" the coach. It does make it considerable easier to do them off the coach but, getting them off, handling them, and re-installing them, without proper equipment, tools etc. is also a pain. But, in the end, you have nice looking wheels. Good luck.
Scott
Scott and Karla
SDFD RETIRED
KI60ND
Donna_and_Rob
Just finished repairing our Kwikee steps, (I accidently let the MH down on them too many times:S) and broke the side of the step right at the rivet. So instead of buying a new one I opted to weld the old one up, (Allen at Ziffel Welding in Valley Springs, Ca.)does nice work. In march we are gonna make the east coast run so I'm trying to get my ducks in a row. The weld job saved us over 300. bucks, of course I had to take it off, get it fixed and reinstall it. Not to hard a job.
Last year we woke up one morning with the coach leaning to the front right. Called the Mechanic and he changed out the right side height adjuster while I watched. Now the left side is hissing so I bought one that I will be changing out as soon as I move the coach and yeah I won't forget to block it up, (I'm skinny enough :B) -Rob
2003 38ft Travel Supreme
350hp Cummins
NaViDa
Finally going to register her today! at DMV!
Full Time, Tree Huggn, Vegan Athlete living on, a shovel of dirt shy of, an acre of land
2007 Toyota Prius
1998 Holiday Rambler Holiday Endeavor 35WGS
:CTime waits for no one
