- btilfanExplorergas, 60
- FloridaRosebudExplorer
hipower wrote:
After seven pages there is seemingly no consensus of an ideal speed. What is apparent is that we should all find our own comfort level as it pertains to our risk of tire failure and personal safety as well as how comfortable you unit is at any speed. An ill handling coach will scare some a lot sooner than others and may be a major factor in driving comfort at any speed.
On an interstate highway we are rarely any more of an impediment to traffic flow than a heavily loaded, underpowered truck so we should not use that as a guideline since traffic copes with that constantly. When traveling secondary roads we should probably try to refrain from impeding traffic behind us when possible. My rule of thumb usually has me looking for someplace to move over and allow traffic to pass easily when I see more than five vehicles backing up behind me. A little common sense is usually a good guide in what we do and for the most part we are successful in getting along with all of the other highway users.
Well put. I would just add that my MH seems to run the best and easiest around 62-65mph. My guess is most MH have a speed where they like to run. - hipowerExplorerAfter seven pages there is seemingly no consensus of an ideal speed. What is apparent is that we should all find our own comfort level as it pertains to our risk of tire failure and personal safety as well as how comfortable you unit is at any speed. An ill handling coach will scare some a lot sooner than others and may be a major factor in driving comfort at any speed.
On an interstate highway we are rarely any more of an impediment to traffic flow than a heavily loaded, underpowered truck so we should not use that as a guideline since traffic copes with that constantly. When traveling secondary roads we should probably try to refrain from impeding traffic behind us when possible. My rule of thumb usually has me looking for someplace to move over and allow traffic to pass easily when I see more than five vehicles backing up behind me. A little common sense is usually a good guide in what we do and for the most part we are successful in getting along with all of the other highway users. - HikerdogsExplorer
MarkTwain wrote:
jplante4 wrote:
Are you talking average as in including stops? We plan for 50 MPH.
To get that, I run 63 MPH on the road when conditions allow.
First buy a Valentine Radar dector. Now you can drive 62 to 64 mph on all interstates without worrying about a CHP using radar on you.
The speed limit on almost all interstate highways is now 70 mph or higher. We travel at 62-65 mph on the interstates most of the time. It seems to be just fast enough that we don't get run over, but not so fast you have to stop at every other exit for gas. With stops we average about 50 mph.
Off the interstates 50-55 mph is about average. Many of the federal and state highways are fairly narrow and have curves that won't allow much more speed - GHOST1750ExplorerDiesel for 16 years, 55-62. Always towing and usually in Ca. Am back to gas now and still pretty much the same speeds. I will usually get a run on a long grade, diesel or gas. Miss the diesel.
- pryoclasticExplorer7.5L gas Vectra here.
The OEM Ford chassis manual says that max torque for this coach is developed around 55 MPH so I set the cruise for 60 and call it done. Sometimes I am doing the speed limit and other times I am under it.
:D
fuelly.com says that towing a minivan nets us an average of 6.7 MPG at the moment:
I do however, fundamentally disagree with comments that rolling at 60 MPH is a traffic hazard. The observations about dangers posed when losing a steer at high speeds are spot on. Look at what happened when an RV here in Oklahoma City was traveling at low city speed limits and lost a tire:
http://www.koco.com/article/rv-crashes-into-northwest-oklahoma-city-apartment-complex-police-say/22150635
Additionally, this flawed traffic hazard assessment does not factor in all the *millions* of safe miles driven yearly by OTR freight hauling semi's who are moving below posted speed limits.
A "safe" rate of travel is more about evaluation of the conditions as they change and risk acceptance as opposed to a flat and static number on the speedometer that makes someone feel good. - doc_brownExplorerDiesel. In California 55mph max since I tow. Outside of the Socialist Republic 63mph, climbing grades obviously slows me down. Over my 14 years with my coach Silverleaf says my average speed has been 43 mph.
- debandiExplorerGPS tells me its 60 and that's good enough for us.
- howdy35Explorer III tend to run 62-65 when towing my CR-V since it says in the owners manual to not tow it over 65 for extended periods of time. I expect many of the posts take into consideration they are towing also. If I am not towing I can run a little faster. Everyone has a speed they are comfortable at and most of the time it is in the 62-65 range. DP
- madkinson74ExplorerJust got back from my first "long" trip in my 99 Gulf Stream DP. I44 speed limit was 75, but that was not comfortable for me in the Oklahoma wind, so 65-70.
About Motorhome Group
38,766 PostsLatest Activity: Jan 10, 2026
