klutchdust wrote:
.........."My RV is on a Chevy Chassis which handles much better than the ones on Ford chassis "
Fact or opinion. I understand the leg room difference based on the engine placement and doghouse area but to say one handles better than the other one I need some stats. . What is your statement based on.
I have a theory. some E350/E450 have handling issues, some do not, the following may explain the difference:
Ford ships all E350/E450 cut aways with identical fixed, non adjustable caster/camber sleeves, "one size fits all". You can recognize these sleeves because they are keyed and cannot be rotated. They are marked "F8UA-AA 0+.25" on the passenger side and "E97A-CA +0-0" on the drivers side.
The RV builder almost never changes the Ford sleeves, as a result:
If the final RV build is nose down one degree then the runtime caster will be about +3.5 degrees. These units can have a real wandering problem.
If the final RV build is nose level then the runtime caster will be about +4.5 degrees. These units are probably indifferent.
If the final RV build is nose up one degree then the runtime caster will be about +5.5 degrees. These units are probably just fine.
So, some Fords have a problem with wandering at highway speeds and some do not have a problem. I once made the mistake of saying all Ford E Series have the problem and I was quickly shot down.
