dougrainer
Mar 05, 2017Nomad
I will find out Monday from HWH. Remember, when items are installed they are installed because THEY ARE deemed necessary. I have never had a problem remounting the cross braces on HWH jacks. I think they are there to keep each jack from having to support each side completely with twisting. You will notice HWH straight jacks pivot side to side and I believe they use the cross brace to keep the system as rigid as possible. MY best guess would be they extended the jacks without the cross brace installed and that slightly bent the mount plate for the cross brace. Should not be a big problem to jack the brace up and use a pry bar to get the alignment and bolts back in. Doug
38,707 PostsLatest Activity: Jan 05, 2014
