lafrentz's avatar
lafrentz
Xantrex RS3000 low battery warn
Have a 2008 Xantrex RS3000 inverter system. Noticed the yellow low battery warn lite on a week ago or so.All is well as far as the systems and batterys are concerned so thinking its a bad Invertor/converter sensor??
  • crasster wrote:
    I'd pull the batteries and put them on a battery desulphator. There can honestly be a number of things causing this. Any other oddball indicators?
    If you were to read previous posts u will see the situation here has been solved.The batteys are 100%.(as good as new) its a faulty led lite
    that's all there is to it. as said 3 post ago CASE SOLVED
  • I'd pull the batteries and put them on a battery desulphator. There can honestly be a number of things causing this. Any other oddball indicators?
  • lafrentz wrote:
    wolfe10 wrote:
    May be accurate, BUT (ya, large BUT) you need to verify by checking voltage at the batteries both before and after plugging in.
    A digital voltmeter is your friend. A "must have" on any RV. Prices start under $20.
    wolf thanks for taking the time to post.I run multi meter for 45 years but if u read my posts I clearly indicated ALL THE VOLTAGES ARE FINE
    all is well and the lite is what it is so no worrys on my part
    case is closed
    What does the Fresh water, holding tanks, battery monitor say? If it says low, the battery is low, if not all is good.
    case is closed
  • May be accurate, BUT (ya, large BUT) you need to verify by checking voltage at the batteries both before and after plugging in.
  • well Xantrex called me and he says in his opinion
    its a weak(bad) LED lite is all and not to worry. so all is well
  • DSDP Don wrote:
    The Manual states when that light is on the battery voltage is low. How do you know what your voltage is? Have you checked the voltage where the cables connect to the Inverter? You could have an issue with cables or connections.
    If you check and find the voltage is correct how about calling Xantrex. Most of the companies will walk you through troubleshooting.
    yes sir Iam well aware of what the manual says. Battery voltages are just fine.thanks for the post reply
  • The Manual states when that light is on the battery voltage is low. How do you know what your voltage is? Have you checked the voltage where the cables connect to the Inverter? You could have an issue with cables or connections.
