Fire, Cast Iron, and Soot
pasusan
I've finally gotten into cast iron cooking. And I want to do it over a fire when we're camping.
What do you do about the black soot that coats the outside of the pan? Do you just clean it off? And - how?
Or do you have a special pan that is always getting sooty?
Not sure about what to do...
Susan & Ben [2004 Roadtrek 170]
href="https://sites.google.com/view/pasusan-trips/home" target="_blank">Trip Pics
15 REPLIES 15
magnusfide
Fuzzyvision wrote:
Lwiddis wrote:
First item to remember regarding Dutch oven cooking is the โ€œfireโ€ should be 2/3 on the lid and 1/3 on the bottom.
Curious what you mean by this
Dutch ovens that are used in campfires have lids with rims to allow the piling of charcoal or coals on top. They also have legs to allow coals underneath. The 2/3 and 1/3 rule mentioned above refers in general to the number of coals or charcoal placed on the lid and on the bottom. There are a number of tables available that bring it down to a kind of science BUT remember, if there is wind or it's cold out, it will affect the temperature of D.O. as well. Experience is the best teacher. I'll list the most helpful links below.
Rollins' Dutch Oven 101
DO Charcoal Temperature Chart
A photo of the campfire dutch oven described above. They come in different sizes too.
"The only time you should fear cast iron is if your wife is fixin' to hit you with it."-Kent Rollins
First law of science: don't spit into the wind.
Magnus
propchef
I assume he's talking about top heat. Some Dutch Ovens have a flat top and a ridge that allows the stacking of coals on top of the unit. This evens out the heat and it cooks more like an oven. If you're familiar with a Caja China, it uses 100% top heat to roast large items, including whole pigs.
pianotuna
Nomad III
Nomad III
I've had good luck coating the outside of the pan with liquid dish soap.
Regards, Don
Fuzzyvision
pasusan
OP here - thanks for all the replies! I'll try the wet paper towel thing... I just want to be able to use my pan on my stove at home too.
What I did was to wrap the pan up in paper towels and a plastic bag - then when I got it home I scrubbed it clean. It was really sooty!
theoldwizard1
magnusfide wrote:
Don't let the myths running around the internet run your life when it comes to cast iron. You can use metal utensils and chain-mail scrubbers on it, just don't use chisels and hammers.
Best laugh I have had all day !
valhalla360
Nomad III
Nomad III
propchef wrote:
valhalla360 wrote:
If it's dedicated to campfire cooking, I would just get a bag and stick it in sooty.
Avoid soap on cast iron. It removes the seasoning and food will stick.
Sorry, but this is a cast-iron myth. I use hot soapy water on mine every time I use them, and I use them almost daily. No sticking issues ever.
As Magnus mentions, cast iron is tough. NOT washing leaves off-flavored residue and potentially rancid oils. Like any pan, they must be washed with soap and hot water.
There are only two no-no's: excessive heat and putting them away wet. After washing, put it back on low heat and allow it to dry completely. No soot issues ever.
Never said, don't wash it. Just not with soap, particularly a strong degreasing soap. While hot, a bit of water and paper towel will remove the food residue if properly seasoned (never had off flavors and my Mom never let us use soap on the cast iron). If not well seasoned, steel wool will typically do the trick.
If you are using them daily, the new oil added probably negates some of the downside of using soap. Particularly if the pan is hot, so you are effectively doing a quasi-seasoning.
Rocket hot is one area where cast iron shines. Spatchcock a chicken then get two cast iron pans near red hot and put the chicken in the bigger pan and set the smaller on top so it cooks from both sides (in this case, the bottom of the small pan needs to be clean and seasoned).
Keeping it dry in storage, I'll agree whole heartedly but even that is salvageable unless the rust gets extreme.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
propchef
dedmiston
Moderator
Moderator
I cook a lot on my smoker and my pans gather a lot of soot.
I agree with the advice for the wet paper towel to just wipe away the soot. You could also use a sponge, but the sponge will never be the same.
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โ€ข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โ€ข <\br >Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
valhalla360
Nomad III
Nomad III
If it's dedicated to camp fire cooking, I would just get a bag and stick it in sooty.
On the bottom of the pan, it's the end of the world but if you feel the need, while the pan is hot (stick it back in the fire if needed), spritz with some water and wipe clean with paper towel. Then make sure it's fully dry (it will happen quick if it's hot) and then wipe with a paper towel with vegetable oil, so it doesn't rust.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
magnusfide
Welcome to the Cast Iron Chef world. We enjoy it.
We use a wet paper towel to wash and wipe off the soot then stow it. No big deal. Then we toss the paper towel into the fire pit to burn. The sand is a good idea if you are boondocking and don't have a water connection.
Cast iron is tough. The only thing you need to be cautious about is to avoid running cold water over a hot pot or pan. The temperature shock will crack it.
Magnus
theoldwizard1
Microlite Mike wrote:
When I was a young kid and when camping cooked almost exclusively over the fire we would put some liquid dish soap (Joy was my mom's detergent of choice) on a paper towel and wipe the outside of all pots and pans including the skillet. A nice even coat of the liquid detergent/soap made it easy to wash off the soot.
WOW ! Brings back Boy Scout campouts !! Pre-soaping the outside helped, but it was not a perfect solution.
We did a lot of beach camping where we landed by boat.
Once the inside was clean (no food residue), beach sand works very well as a scouring powder to clean the outside. Old fashioned Brillo/SOS pads work the best.
Face the fact, they will never be "like new" on the outside again !
opnspaces
Navigator II
Navigator II
Try plain old water and see what happens. You could also use soapy water but no scrub brushes.
Or put the cast iron in a bag and just use it sooty next time.
Lwiddis
