Pizza Stone Question
WoodGlue
I won't be using a pizza stone but a large square unglazed tile. My question is:
Where in the oven do I place it? On the very bottom in the RV stove, or on a rack? Then, where do I place the dish I'm baking? I have the standard Atwood/Wedgewood RV oven and whatever shelves/racks came with it as standard.
Thanks!
WoodGlue
2002 Land Rover Discovery II
2014 Lance 1685 - Loaded - 4 Seasons - Solar - 2 AGM's
When Hell Freezes Over - I'll Camp There Too!
Lance Travel Trailer Info - Lance 1685 Travel Trailer - Lance 1575 Trailer
24 REPLIES 24
Mocoondo
bhh wrote:
I get this too, but once a year or so, I run it through the electric oven self-clean cycle. Comes out like new, but needs re-seasoned.
I would never. That black char is the "goodness" that makes the pizza so much better.
bhh
Mocoondo wrote:
My current pizza stone is charred black from so much use.
SWMO
I suspect for the purpose of evening out the heat in the oven a 12"X12" pan with 1/2"of sand would work well.
2009 Dodge 3500 Laramie, DRW, 4X4, auto, 6.7L, B & W Companion.
Jayco Designer 34RLQS, Mor/Ryde
Super_Dave
I think this is a personal preference issue and don't see a right or wrong answer. I have tried both positions with successful results. The one thing I can say for the cooking rack position is that I've never broken a stone in that position. I have broken a stone on the bottom.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
SWMO
It depends on the purpose. If you are trying to eliminate hot spots in the oven permanently, then cover the burner shield between the vents and force the heat up the sides of the oven. If you're going to use a baking stone to bake on then it should be on the rack.
Mocoondo
fanciesmom wrote:
All that said - if you are using unglazed quarry tile PLEASE MAKE SURE IT DOES NOT CONTAIN LEAD if you plan to cook pizza or bread directly on it! A lot of the quarry tile contains lead which will poison you.
A pizza stone that is made for pizza/bread/etc. will be lead free.
Agreed. I don't think I would be using floor tile or whatever the OP indicated to cook food on. The two items are not the same. A good pizza stone is only $20 or so and will last for a very long time. I cook pizza on my stone all the time. In the oven, on the grill, wherever. My current pizza stone is charred black from so much use. I will be devastated when I finally break it.
One thing I learned is that when shopping for a pizza stone, pick a good one with handles on it so you have something to grab on to. My current one does not have handles and it can be a bit tricky getting it out of the oven (or off the grill) when it is hot.
fanciesmom
Mocoondo wrote:
WoodGlue wrote:
What do you do if a dish, say a frozen meal, calls for you to bake it on a cookie sheet?
If a meal calls for baking it on a cookie sheet?
Well, you would place the frozen meal on a cookie sheet as instructed. I suppose if you wanted to place your frozen meal on the pizza stone, you could, but then you are not following the instructions because it says to place the frozen meal on a cookie sheet, not a pizza stone.
A pizza stone is not supposed to just be placed in the oven and left there with no function. It is designed to be cooked on in this fashion:
Placing it at the bottom of the oven with nothing on it, or placing a baking sheet on top of the pizza stone would not be correct usage.
You are correct. Your food is supposed to cooked directly on the stone. If you are putting a frozen meal (or a wet container) put it on a cookie sheet on the stone.
Paranoia is only hindsight in advance.
Mocoondo
WoodGlue
Mocoondo wrote:
korbe wrote:
We put our stone on the rack and set the baking item directly on the stone. Just a one shelf oven.
This is the correct answer. You are supposed to cook directly on the stone. The stone is used in lieu of a baking sheet and is placed on whichever rack you want.
Thanks!
WoodGlue
Mocoondo
WoodGlue
Thanks everyone!
WoodGlue
Ron3rd
WoodGlue wrote:
I figured that the tile would sit on the bottom on the stove, so it's a good thing I asked!
WoodGlue
Woodglue, we've done it both ways and I don't think it makes a big difference. Lately, we've been putting the stone on the lower rack and place whatever we're cooking (pan, casserole dish, etc) on the stone. I've used tiles and pizza stones and they both work fine btw.
Equilizer Hitch
Honda EU2000
camper19709
x2
On the metal heat shield above the burner...below the rack.
Don't be surprised if the tiles or the pizza stone break.
Sometimes they do break but just leave the pieces on the metal shield.
Broken or not, you will still get protection from burning your food.
Chip
06 SurfSide
30ft class A
2 slides
Ford V10 chassis
04 Chevy Astro van toad
bigcitypopo
I put mine right on the metal heat shield in the stove... Below the rack... Works great. We can make perfect brownies!
2014 RAM 2500 BigHorn CrewCab 4x2 ShortBox, 6.7L CTD
2014 Keystone Springdale 294bhssrwe - Hensley Arrow!
The best wife, 2 kids and a bunch of fun
