bonse's avatar
bonse
Slow Cooker Beef and Broccoli
Another recipe that's easy to do. I love using my Crockpot
Yield: 4 servings
Prep Time: 10 minutes
Cook Time: 3 hours 50 minutes
Ingredients
1 1/2 lbs beef chuck (roast or chuck steak), sliced into thin 1 1/2-inch long strips
1/2 yellow onion , sliced into 2 portions
1 cup low-sodium beef broth or beef consommé*
1/2 cup low-sodium soy sauce
1 Tbsp sesame oil
1/3 cup slightly packed dark-brown sugar
3 cloves garlic , minced
Salt and freshly ground black pepper , to taste
2 1/2 Tbsp cornstarch
3 cups broccoli florets , diced into bite size pieces (from about 12 oz broccoli crowns)
Sesame seeds , for garnish (optional)
Instructions
1. Add beef and onion portions to a slow cooker. In a mixing bowl whisk together beef broth, soy sauce, sesame oil,
brown sugar and garlic. Season mixture with salt and pepper to taste. Pour mixture over beef and onions in slow
cooker. Cover with lid and cook on low heat 2 1/2 - 3 1/2 hours, until meat has cooked through.
2. Ladle out 1/4 cup of the broth from slow cooker and pour into a bowl. Add cornstarch and whisk until smooth then
return broth mixture to slow cooker and gently stir. Add in broccoli pieces (if you want vibrantly green broccoli you
can steam it instead then add it at the end) and cover slow cooker with lid, then increase to high heat and cook 20
minutes longer, or until broccoli is tender and sauce has thickened slightly. Remove onion pieces. Serve warm over
white or brown rice sprinkled with optional sesame seeds.
3. *I used low-sodium broth (as well as the low-sodium soy sauce) so I have better control over the amount of salt that
goes in. You can use regular beef broth, you just might not need to add salt, and same if using the consommé
    Yield: 4 servings
    Ingredients
    1 Tbsp sesame oil
    Instructions
    I would personally skip the added beef broth, adding only equivalent in plain water then simply add some salt to taste. The beef WILL "flavor" the liquids while slow cooking.
    Since you are already slicing up the beef, cooking even 2 1/2 hrs most likely is not needed as the thinner slices of beef will be well cooked and tender in less time than if you put a whole roast in.
  • I have made this recipe a few time and really like it. As written, I think the sauce was very thin. Adjust flour if you like more of a gravy.
