sjturbo wrote:
...My regulator is the way of the handle so you cannot get a full grip to carry.
Your hands must be much bigger then mine. I just went outside to observe the right handle, and how my hand fit it. I then grabbed the left handle, picked up the grill, and noticed that the handle fits the shape of my fingers just fine. I was just using my fingers to lift the grill, not trying to wrap my whole hand around and it felt natural to do.
The grill, even with stand, is not very heavy, and I expect the average person can carry them with their fingertips. And, in doing so, never even notice the regulator.
sjturbo wrote:
Second, in order to attach a 1lb propane container the valve and regulator must be "flexed" outward because the container will not thread on straight without hitting the rear leg...
First, use a hose.
Second however, I will state that I just put together a Q1200 for my sister, and she doesn't grill often, so I put a green bottle on her assembled grill. I don't recall having any issue whatsoever with installing the bottle. It screwed right on and the grill fired right up.
First, again, use a hose. The individual bottles are EXPENSIVE if you grill often. There are two good options to save money in the long run. I've done both.
1)Purchase a small 1 gallon (5#) LP bottle. These are expensive, but at $2.00 per GALLON instead of $2.50 for a POUND, it does not take long at all for the smaller bottle to pay for itself. Consider also how many fewer trips, and fuel saved, with the larger capacity tank. The larger tank, in my opinion, is also safer as it is less likely to leak.
5# Vertical LP TankI have a review on that page with this same user name.
2)Add an stay-a-while type device to your RV. This is my preferred method if I am going to be parked for an extended length of time. The 'stay' has a hose that can be used to tap into it with the other end just like is found on the small bottles.
Stay-a-WhileHope this gives you some ideas.
